Great news for rooted android users--Viper4Android
Jan 13, 2016 at 9:58 AM Post #106 of 222
i really really really would appreciate if anyone can make a convolver for me to make my audeze lcd 2 rev pre-fazor sound musical with big bass, and warm
please any help, i will be using
android--- v4a--- mojo---- poweramp---- audeze lcd2
i have been struggling to get the audeze lcd2 sound to my liking for so long
OK, here you go, give this a try
for V4A driver status of 44100Hz: https://www.dropbox.com/s/1mt41onepp2qgnq/110Hz%20%2B8dB%20low%20shelf-44k.irs?dl=0
for V4A driver status of 48000Hz: https://www.dropbox.com/s/pz6qf2bl9wtjeuk/110Hz%20%2B8dB%20low%20shelf-48k.irs?dl=0
Although, for your application, either should do fine
Jan 13, 2016 at 3:09 PM Post #107 of 222
Tried both and still no dice. Even tried freezing Knox with Titanium Backup but SELinux mode changer doesn't seem to work. After installing and granting root access, tapping the permissive mode doesn't seem to do anything. getenforce still returns enforcing.
Getting desperate here =(
Edit:] Apparently SELinux can't be set to permissive on the Samsung kernel. Looks like I'll have to flash a custom kernel. Ugh....everything was working so well on JB. Stupid Lollipop... :mad:
I would find kitkat and flash it back onto your phone then it will work. I couldn't get it to work with lollipop at all and tried everything so I flashed kitkat back onto my s5 and it worked perfectly.
Jan 13, 2016 at 4:34 PM Post #109 of 222
Which version of kitkat are you using?
For my phone I'm thinking of using I9505XXUGNJ5, assuming the new bootloader plays nice with kitkat :rolleyes:
Initially after flashing to Lollipop I wasn't overly impressed so I restored my 4.2.2 nandroid backup but the new bootloader from flashing to 5.0.1 messed it making the SD card and wifi inoperable. :(
Definitely a kernel issue, flash a non stock kernel, you should be good to go.
Is there a kernel for the GT-i9505 that you would suggest? I'm looking at the Imperium LL Kernel v3.1
If that doesn't work I may just go with a custom ROM.
Jan 13, 2016 at 10:21 PM Post #111 of 222
Not too sure, but maybe one that has selinux set to permissive.
Most custom kernels will have SELinux set to permissive. Imperium Kernel is no exception. I'm just apprehensive about custom kernels as some can negatively affect things like battery life. If a kernel came with a recommendation I'd be more willing to try it out.
Guess I'll give Imperium Kernel a spin and see how it goes.
Jan 14, 2016 at 12:38 AM Post #113 of 222
You can always flash the stock kernel back.
Looks like I might have to go that route after all. Flashed Imperium kernel and now soft keys don't work. In addition, even with a custom kernel with SELinux set to permissive, the V4A drivers still refuse to install. What a pain...maybe I'll try downgrading to 4.4.4 or a custom rom.
Jan 14, 2016 at 2:59 AM Post #114 of 222
thanks so much i will try it today
Jan 14, 2016 at 7:44 AM Post #115 of 222
I had that issue with my Note 3,flashed a custom ROM with it baked in. You are on xda, obviously, have you done a search there? Try posting for help? I'll try and do some researching today for you.
Where did you install viper from?
Jan 15, 2016 at 2:43 AM Post #116 of 222
Are you using a Lollipop based rom?
I am on XDA but suggestions there have turned up empty as well.
The V4A is from the official thread on XDA.
Jan 15, 2016 at 2:30 PM Post #118 of 222
Yes, on lollipop. Had it running on my Note 4 a d my lgv10. I've had trouble in the past, for whatever reason installing v4a from the official thread. Try the Google play version, maybe that will help.
Just tried the Google Play version and the same result :(
I'm going to try a custom ROM next. Will report back. Thanks for your help!
Jan 15, 2016 at 2:47 PM Post #119 of 222
Sorry, wish I could be of more help. Custom ROM with it baked in should do the trick. What exactly is going wrong, drivers not installing correctly?
Did you try going into your settings-sound? I forget exactly where it is, but there is a setting in sounds for changing equalizer or something regarding the sound. I have my girls old note 3, going to check that.
Try this:
https://m.reddit.com/r/galaxys5/comments/35mavs/help_enable_viper4android_rooted_galaxy_s5_on/
Let me know if you need help running the script.
Jan 15, 2016 at 3:13 PM Post #120 of 222
i have bad luck could not try those settings with my audeze as i sold it
now i have the oppo pm1 can i get you to make me ones for the oppo pm1, i really am sorry to disturb you
