Baten
- Sep 13, 2012
4.4mm will be able to go a lot louder, because balanced can use an amplifier per channel, unbalanced won't be able to achieve same volume.Is there sonic upgrade if i connect RCA in to 4.4mm headphone out, as opposed to unbalanced out?
So, it all depends on power requirement of your headphones. If unbalanced out gives enough juice you're fine, otherwise 4.4mm is worth looking into.
