Mercuttio
Key Conspirator in the Quest to Murder Music
- Apr 22, 2005
Those most certainly will not have a serial number. Fantastic find, and they look to be in ideal condition. Can you take a close up picture of the drivers?
The foam pads are only adhered to the cups because they were never removed early on... the wood treatments that Grado applies seem to take a while to cure, and generally they put the pads on before they are fully cured. If you're gentle you can probably remove them without any damage to the pads, and you most likely cannot damage the wood. Some black foam might still remain, but you can rub it off gently.
I do not suggest trying these with newer bowl style pads though... they're tuned for flat pads.
Here is the box...I think the latch points to Vintage S or Vintage A.
And here are 'phones as presented in the box. It smells old when you open it up and as you can see, the felt is coming unglued and is thus curling up around the edges. The pads seem to be adhered pretty tight to the wooden cups and I'm afraid I'll permanently damage them if I force them off the look for a serial number. Would RS1s of this vintage even have a serial #?
