fjrabon
- Feb 1, 2009
The Sennheisers don't need higher output impendace or 2nd order distortion; the bass is already distorted enough and high output impedance will just make them warmer, not power the bass the headphones have. It might increase the midbass hump but not actually be able to power the increased bass that the highter output impedance provides! What they need is an amp that can swiing the voltage swing well and nimbly.
These tiny little solid state amps like the M9XX, Magni 2U, Mojo, and the infinitely worse O2/Element just can't do that or open the headphones up. The headphones get loud but the staging is weak and the bass doesn't hit fast enough if it even hits decently hard on the M9XX and Magni 2. Instead of double kick rolls and fills in something like Motorhead being THUMP THUMP THUMP THUMP THUMP with each thump starting and stopping on a dime or continuing to linger while the next one starts anew (like how they sound in real life), you will just get THUUUUUUUUUUUMMMMMMMMP mud and then the sound of the beater hitting the drum skin. This is very recording recording depedent and also of the amount of compression used in recording and mixing too but is an easy way to.
It just so happens that these OTLs and hyrid tube amps that cost only a couple hundred bucks can swing voltage really well despite being a bit hazy (you need to move up to OTC to get rid of the haze/grain) while for solid state you really need to get something at least as good as the Asgard 2 (if you like neutralish. You might like the the Cavalli Liquid Carbon if you like syrup or HPA-3u/b if you like Chi-fi, opamp-rolled warmth or Audio GD if you like Krell sound). These midget amps just don't really get the job done even if the headphones are listenable or okay on them.
I don't think voltage swing means what you think it means. The m9XX provides essentially infinite current, which is what leads to the effects you're talking about, not voltage. Voltage essentially just leads to greater volume without distortion, it's current that impacts things like transient response. And again, the HD800 and HD800s have the same power requirements as the HD600 and HD650 anyway, and thus the fact that the m9XX performs well with the HD800s, but not the HD650 is left unexplained.
Finally, the Asgard and the m9XX swing almost exactly the same voltage and the m9XX provides a tiny bit more current, yet you recommend the Asgard? Also I'd say from personal experience the Asgard is as bad of a match with the HD600 as the m9XX and Magni are. You just sound like you're repeating half understood semi-truths. And I say this as somebody who owns a world class OTC amp and would thus love to proudly say you're right. But you're not. There are benefits to OTC designs, but it's not "swings more voltage"
