Listened to these for a bit over an hour amped an around 10 mins unamped.
All I can say is wow. I definitely prefer these over my SRH840. If Shure ever resends the 840 to me, I assure you they will see seldom use.
First off comfort is the best I've ever had in a headphone.
Construction is also flawless so far. Cable is phenomenal.
Now on to sound. I've listened mostly to rock for you.
These sound like the DBA-02 but with an ever bigger soundtage, slightly more bass, and slightly more detailed, clarity/transparency.
The sound is very mid-centric and are slightly-forward/bright.
In my opinion rock sounds the BEST that way. Guitars sound amazing on these; the slightly forward mids makes the guitar a little more apparent in rock. If you love guitars in your rock these are a no-brainer.
Vocals are somewhat also a bit forward. Vocals are extremely clear and heard.
The bass is absolutely good for me. The bass extension is great; these can sound very very low.
On some songs you'll laugh when people say "they have no bass". I find that ridiculous.
I think the bass quantity is average but sounds a little less thanks to forward mids. It's perfectly adequate for me however.
The only thing a bit lacking is the bass impact which I personally mind very little. When people complain about the AD700 it's not the quality of the bass; I know now from hearing these it's the impact.
I can't believe it when I hear people giving up on these because of bass. Seriously the mids-highs, bass-extension, comfort, build, soundstage, transparency, and clarity are WAY too good to dismiss these. Bass is perfectly adequate to me.
Unamped they sound extremely good as well. Very similar to it amped.
I think an amp will improve the SQ on these from 5% up to 15% at most I believe.
If comfort, bass, or even SQ is a problem check out this mod:
http://www.head-fi.org/forum/thread/505053/audio-technica-ath-ad700-fit-and-comfort-mod
To fix bass just use an EQ.
I haven't used an EQ or modified yet these personally yet though because I'm perfectly happy with how it is right now.
pete99 What are you still reading for? Seriously go get 'em now! These are my favorite headphones I've ever owned!
Wikipedia: ‹C› is the third letter in the Latin alphabet.
»![](http://static.smarterfox.com/media/wiki-favicon-sharpened.png)
![](http://ff.duckduckgo.com/favicon.ico)
![](http://surfcanyon.com/favicon.ico)
