Nov 11, 2024 at 11:29 AM Post #66,751 of 70,148
Question for those Bowers and Wilkins fans, did these guys ever update their software or have firmware updates?
I've never seen an update on any B&W tws I've ever owned :rolling_eyes:
Nov 11, 2024 at 11:55 AM Post #66,752 of 70,148
saw the Jabra Elite 10 V2 on sale for $199 so grabbed a set.
The transparency mode is amazing for voices. It's not as good for the ambient noises around you as the Pixel Buds Pro 2, but for voices, it's just really good. I have had a few conversations with these in and one point I was wondering if they were even in my ear. ANC is definitely improved. I would just like to stick the sound of the MTW4 into these because these do everything so good from the size, form factor, battery life, ANC, Transparency, respectable app. SQ is good but it's just not as good as others I've heard.
Nov 11, 2024 at 11:56 AM Post #66,753 of 70,148
My wife, who has never shown any interest in audio, has asked me for a TWS that she can sleep in (listening to audiobooks puts her to sleep, but any noise keeps me awake, so TWS would be a good compromise). What are some recommendations for TWS that are both comfortable and low profile?
Nov 11, 2024 at 12:29 PM Post #66,754 of 70,148
I had the 10 v2 - while theyre decent TWS with good ANC, they would just not auto connect to the iphone, which is a known problem (see jabra subreddit) - and jabras solution was that "we will fix it by next year" so I returned them.
Nov 11, 2024 at 12:32 PM Post #66,755 of 70,148
Soundcore A20 maybe?
Nov 11, 2024 at 12:39 PM Post #66,756 of 70,148
Nov 11, 2024 at 12:43 PM Post #66,757 of 70,148
that's a bummer. zero issues with android fortunately.
Nov 11, 2024 at 12:44 PM Post #66,758 of 70,148
Soundcore Sleep A20
I've used these a half-dozen times. They are comfortable and almost disappear in my ear. I'm still surprised they work while side sleeping. I use a memory foam pillow. The sound is ok NOTE: Not for bass heads : )
Nov 11, 2024 at 1:17 PM Post #66,759 of 70,148
Hey all,
Letting my gemini ii go. They're a good set. Small, solid resolution, good bass, but I prefer my ZX1. That's subjective, as I do think the gemini ii are a really good set.
DM and I can ship tomorrow.
Nov 11, 2024 at 4:02 PM Post #66,761 of 70,148
Nov 11, 2024 at 4:23 PM Post #66,763 of 70,148
Nov 11, 2024 at 4:28 PM Post #66,764 of 70,148
Apple airpods 4 ANC.
Using it on a Google pixel 9 pro fold Android phone. ANC is pretty good for an open type design. It effectively eliminates soft whirring sounds like air-conditioning and fan. Loud low rumble like bus engines still get through, as do voices. Transparency mode sounds similar to turning off the ANC and let in the same amount of ambient sound. Soundstage is wider than the airpods pro 2 due to its open design.
They have prominent mid bass and not much sub bass. Mids are clear and sounds natural. Highs are smooth and not sibilant, but they do sound thin. Turning up the treble range a few notches in Wavelet brings out the highs and makes it more resolving. Overall a warm sounding pair of earbuds.
The fit is dependent on the user's ears, since there are no rubber sleeve of different sizes to accommodate to different ears. They are made up of hard plastic, but they are surprisingly quite comfortable and secure in my ears. Battery life is pretty decent with about 4.5 to slightly less than 5 of hours of playtime with ANC turned on. The case is tiny, there's no more physical pairing button, pairing is done by double tapping the area below the case's LED light.
Any issues with music not playing after charging them?
I had an issue with my 1st pair. Might have to try them again.
