Not so fat head
The Wf-XM5’s I picked up at Best Buy says made in Vietnam, according to the internet, they’re made in China…. Fakes?
HIFIMAN SVANAR
50% off at Amazon. FOMO get thee back !!!!! https://www.amazon.com/dp/B0C73D3RQK?th=1&psc=1
That is really tough to pass on. The Svanar are legit good even at $500.
18 days after buying on Amazon no shipping. WTH? Amazon is the seller, HiFiman shipper. I pulled up the listing again, it said 4 days shipping > from HiFiman. I canceled the 1st order and I'm listening to them from 2nd order 4 days after buying.It is the closest to an audiophile tuning I have heard in a TWS. I love it. If using LDAC, start the music, then hit the Bluetooth button to disconnect, and immediately hit the Bluetooth button to reconnect, and the connection is stable.
I have an open chat conversation w/ Apple Support. Any device or software I have a questions about: I type my question and a support chat starts about the issue. Usually it is handled via text.I must be the minority, because I've never had bad luck with Apple. They're great.
The BT11 is taking a beating via the comments in the thread here and on Reddit, FiiO even admitted in not so many words they are Beta testing it on us.
I have both and the BT-W6 is far more polished right now and has a fully working Windows App that you can set it up on and move to phone/Mac/games console etc.
The lack of LDAC is not an issue as I knew that to begin with and Creative have never done so and all my phones have supported it from 2016.
I can do LDAC via my BTA30 PRO also the Alt AD2P driver just as well as with the BT11 so the claim of better distance due to their ground-breaking antennae design etc is BS IMO.
The only advantage is I can now use my FW5's properly with LDAC on my PC as both devices shoehorn LDAC onto a chipset that does not support it by using Snapdragon's compression as without it you would be stuck with 600k instead of 900k but it can act up regardless.
If I use my FiiO FW5's with my PC it is 90% of the time via the Creative Dongle (previously BT-W4/5) for aptX Adaptive and the same on my phone or LHDC both of which are better than LDAC all round including SQ/Latency and Battery on the exactly same devices so an apple to apples comparison
What do they mean by "bit-perfect" audio?Anybody use USB Audio Player PRO? Anyway to get bit-perfect output with TWS? Or is that not possible since it would means max volume on the earphone?
Not sure about case charge level in the notification drop down or what phone you are using but when my I open my Buds3 Pro case and the GB3P connects to my Fold 5, I get a popup showing me battery level for the left and right earbuds and the case. I also use the Buds3 Pro widget which shows me this information as well.I found something annoying about the GBP3. The case charge state is not indicated when I have the earphones on. Linkbuds S shows you the case charge level as default easily, and automatically indicates as a notification.
Is it possible have GB3P to have a notification on drop down for the charge level of the case? I don't want to go digging after this at times.
My widget only shows earphones charge levels, not the case. I don't know what happened!Not sure about case charge level in the notification drop down or what phone you are using but when my I open my Buds3 Pro case and the GB3P connects to my Fold 5, I get a popup showing me battery level for the left and right earbuds and the case. I also use the Buds3 Pro widget which shows me this information as well.
I will admit I like the SQ of Svanar. I don't know what it is, but I like how music sounds no this TWS. The measurements don't look all that great in the treble, but for some reason, I like the way it sounds for music. This is very hard since I don't like the build quality, and I also want really great ANC.HIFIMAN SVANAR
