Aug 25, 2024 at 12:44 PM Post #64,651 of 70,865
Any word on how well the Bowers & Wilkins Pi8 holds connection?
I loved the HiFiMan Svanar, but they drop connection whenever I’m outside the house, which makes them completely unworkable.
I’m looking for an improvement over my AirPods Pro 2 that work as well in most other things (I’m okay with slightly less “clamped down” ANC).
And I can keep using my AirPods Pro 2 for workouts.
Mine have been working great in and outdoors. No issues so far. No BT disconnects. They resolved the disconnect issues with the PI7 S2 and so far with the PI8 in my world. Fingers crossed that it lasts...
Aug 25, 2024 at 12:47 PM Post #64,652 of 70,865
The price was so very right, so I'm back trying out the Final ZE8000 MK2. Really liked the first gen and these aren't a huge upgrade but for $259, I couldn't resist!
Aug 25, 2024 at 1:13 PM Post #64,654 of 70,865
lmao how do you get time to try all this? Even one new thing every fortnight and im overloaded lol
Aug 25, 2024 at 1:19 PM Post #64,655 of 70,865
Tiny bursts. Depending on what the family is doing. Some stuff is leaving though -- ie, sold.
The Final buds aren't a pair that I'd even try wearing outside. I look like Frankenstein. Home/office use only. 8k is real.
Aug 25, 2024 at 1:22 PM Post #64,656 of 70,865
the Finals look like the smart way to build a tws, battery in the stem and freed up driver housing, although the driver housing is small.
If someone would lean into that design I think we'd get a nice fidelity jump as the housing would be free up for drivers!
Aug 25, 2024 at 1:31 PM Post #64,657 of 70,865
The thing with the Svanar I found was that once they connected if I hit the Bluetooth button on the phone and disconnected then reconnected my connection became solid, but not on initial connection.
Aug 25, 2024 at 1:49 PM Post #64,659 of 70,865
Is there anyone that owns the aviot te-zx1 that also has the b&w pi8 or it is too early for that?
I would love a comparison between those two, both for sound quality and anc
I don't have my TE-ZX1 anymore but very much prefer the PI8. I wasn't a huge fan of the Aviot. Others will disagree...
Aug 25, 2024 at 2:01 PM Post #64,660 of 70,865
I will compare to both the ZX1 and ZX1 PNK. Yesterday, I spent 10 hours on planes listening to both AVIOTs using Tidal. It will be tough to beat them. I think it was you? who said 'I compare them with full-size headphones'
It's raining and I have a busy couple of days ahead. The Pi8s are 2nd up.
Aug 25, 2024 at 2:59 PM Post #64,662 of 70,865
One drawback I am noticing with the Jabra 8s is due to their closed design, there is always some kind of internal noise from even the slightest movements. Gotta think about this purchase for another day or two...
Aug 25, 2024 at 3:11 PM Post #64,663 of 70,865
Aug 25, 2024 at 3:43 PM Post #64,664 of 70,865
How is fit and wind noise reduction on the 10s though? I am asking mainly for biking.
The 10 has an unusual fit compared to to typical IEM/TWS. It's has very unique tips and almost zero ear pressure as a result.
But it will feel unsecure to start due to its design. This does not mean it actually loose. It just feels that way. You need to just wear them until your brain adjusts. Once adjusted you will stop worrying and just enjoy them. I use mine in the gym, on walks/jogs and don't think I would have issue on a bike unless I was doing extreme mountain biking or something like that.
Aug 25, 2024 at 3:45 PM Post #64,665 of 70,865
Are you by chance able to give a brief comparison on the Pi8 vs the Triump? I liked the sound and design of the Triumph but had connection issues and bad transparency mode through 2 sets (higher pitched sounds created static noise in transparency).
