Jan 23, 2024 at 7:37 PM Post #59,883 of 69,960
Thanks. Weird. Plugged in all day.
Just a thought, if you haven't tried this already.
Plug the charge case into a low output USB source (possibly a computer) & allow it to charge.
I did this once with a charge case (different brand) that would not accept a charge from a phone power bank. I left it on charge status for around 8 hours, and after doing so the charge case was fully charged and would allow for future power bank charges.
I'm guessing the charge case battery was extremely low and needed some tlc through a trickle charge.
If that doesn't work, then contact hq and work with them directly.
Cheers 🍻
Noble Audio Stay updated on Noble Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/NobleAudio https://www.twitter.com/noblebywizard https://www.instagram.com/nobleaudio https://nobleaudio.com/en/ contact@nobleaudio.com
Jan 23, 2024 at 10:07 PM Post #59,885 of 69,960
Cheers 🍻
Thanks. I think I got them going again. I’ll report back but yeah the case was pretty dead.
Jan 23, 2024 at 10:39 PM Post #59,886 of 69,960
Hands on: Sennheiser Momentum True Wireless 4 review​
They mention 20ms via a Dongle, not sure if they are talking about their existing Dongle or have something new and better in the pipeline.
https://www.whathifi.com/reviews/sennheiser-momentum-true-wireless-4
I can't wait. Just put in a calendar reminder for the 15th to pre order these.
Love every upgrade here, send like lots of great touches, like the charging mode additions, the better anc and microphones, similar driver to the ie600, and the rest
Besides not making the case smaller.
Jan 24, 2024 at 3:41 AM Post #59,887 of 69,960
Jan 24, 2024 at 12:21 PM Post #59,889 of 69,960
I had the exact same issue. Although I did notice that my case still had 3 LED's before it went completely dead. It happened twice so I don't think that's normal behavior. Kai has offered some support and I'm keeping a close eye on my next charge/dead cycle to see if it happens again. Might be a faulty charging case.
Jan 24, 2024 at 12:50 PM Post #59,890 of 69,960
Just curious, do you live in a cold climate? I ask because sometimes batteries getting cold = bad ju ju
(Batteries in general, not sure about charge cases)
Jan 24, 2024 at 1:16 PM Post #59,891 of 69,960
That would be a yes. :) Toronto Ontario to be precise and it's been hitting -20ish Celsius on a few days but I'm not outdoors that often or long enough I would say for it to cause an issue. At least I hope?
Jan 24, 2024 at 3:10 PM Post #59,892 of 69,960
Seems like the biggest selling point.
But what does "similar" mean?
Well the Porsche is similar to a VW right?
Yeah, mine went from charged to dead kind of immediately. So I'll monitor it as well.
Jan 24, 2024 at 3:18 PM Post #59,893 of 69,960
So I may just be done with Bluetooth buds. The MTW3 that I got not very long ago is having issues. The left bud is dead and won’t charge. Kind of makes me mad, very disappointed.
Today when I went out I just used my Truthear Hexa. I used a shirt clip to clip the wire to the collar of my shirt, and stuck the wire inside my shirt, then into my pants pocket and plugged into an Apple dongle and then my phone. A few more steps and a tiny bit more of a hassle than a set of TWS buds, but they won’t die in the same way a set of TWS buds, and they definitely sound better than my AirPods Pro gen 2.
Jan 24, 2024 at 9:09 PM Post #59,894 of 69,960
I hardly use my MTW3 due to discomfort but I have tried them again and now noticed the the Blue LED (Wear Sensor) is not working on the right earbud, tried cleaning them and will do factory reset if nothing then RMA.
If the new MTW4 are same shape/fit then they are a no go for me and the real battery life is pretty poor at about 5.5hours with my usage.
