The Edge 30 Ultra does since the Android 13 update, or at least it does on paper! I've seen it work, but it's not stable. I saw the same thing on an Edge 40 Pro with Android 13 out of the box.The Edge 30 doesn't support Aptx Lossless
On Android 12 I was using regular AptX Adaptive with the DPP with no issues there, but since the update I had to force normal AptX or the cutouts would be constant. Bluetooth will always try and give you the "best" codec, so it would usually default to the 44khz but then after a minute or so switch to 48. And then cycle back and forth endlessly. Each time doing that I'd get an interruption.
Motorola are aware and I've seen other issues relating to LC3/LE in their forum, but I'm not holding out much hope of a fix any time soon. Luckily my current main guy the MTW3 doesn't have the fancy new codecs, so the AptX Adaptive there works fine.
