Hyperfluxe
How do the main true wireless IEM's (Jabra Elite 65t Active or regular, Bose SoundSport, Bragi Dash, etc) compare to the best "not true" wireless bluetooth IEM's like the Advanced Model 3?
I can’t speak for advanced 3 but I have rbh sb, and have had the ma750 wireless and the Vmoda froza metallos which are all some of the best sounding bt iems I’ve ever heard. The bose and the beoplay are a step behind in sq. For gym use and commuting I find them very good but for listening sessions I have a second pair of higher quality iems.How do the main true wireless IEM's (Jabra Elite 65t Active or regular, Bose SoundSport, Bragi Dash, etc) compare to the best "not true" wireless bluetooth IEM's like the Advanced Model 3?
Intuitively, it makes sense that wired BT > true wireless BT in terms of SQ. I just don't feel like the market is mature enough for good true wireless IEM's - all options are less than ideal. Bose SS has poor isolation, Bragi Dash and Jabra Elite 65t don't have good SQ according to r/headphones. Also they're expensive.
If you are looking for an endgame all for one I agree with you. Seems like the market has focused on sports use and connection stability first and sq is lagging behind. Hopefully the next round will up the ante on sq.
Does Active 65t justify the $20 increase from regular 65t?I got lucky when I first looked at it on best buy online they had a price of 170.00 so I printed it out and I tried to order it and the site glitched and price changed to 189.99! I took the print out to best buy and they had to honor it but they didn't have it in stock so they will be delivered on the 25th. Anyone want buy a set of samsung iconx 2018 with brand new comply tips? I'll be posting these on the forums soon.
I think so, much better sweat and dust proof protection, salty sweat can damage headphones pretty quick. if you plan on using for gym which I do I would get the active version plus it has motion detection to use with exercise apps to keep track of reps, miles ran stuff like that. if your just using casually, not working out then just get the normal 65t model, they are excellent!
