SynaestheticA
Of course, my bad. Call quality is of no importance since primary use would be for music listening while commuting. Good BT connectivity is certainly a factor. And I'll be using the earphones with the following DAPs: Shanling M6, Hiby R8 and iBasso DX320. ANC doesn't have to be top of the line, either, but if it can cancel outside noise more effectively than passive isolation from regular IEMs it would certainly be a plus.
So, sound quality will be foremost to me. I am not too fussed about tuning either, but prefer warm, mid-centric sound with good vocal presentation.
If it fits your ears I think the DPP is the best for sound quality.
Also if you're listening on a train the Svanar ANC sound is ruined by most accounts.
DPP ANC is solid and does very little to ruin the frequencies.
Consider its size tho. In my ears I think they look cool and they are pretty comfy.
All that being said, if mids are more important to you than soundstage and the low end maybe a noble or Svanar would be better, just not as unique
