- Sep 8, 2014
I had the opposite experience in terms of fit. I couldn't get the left AZ60 to seal well (regardless of what I tried), so bought the MTW3 and found a better fit.MTW3 is bassier (bass has more impact), a little darker in general, mids are closer and highs slightly more metallic (in a good sense to me at least), I have impression AZ60 soundstage is fuller and more detailed. ANC similar - not great but sufficient, comfort similar, fit - with MTW you have to find your fit with using various wings, AZ60s fit like gloves.
In terms of sound, they are both on the same level imo, with the AZ60 being slightly smoother and the MTW3 having a little more low end and treble. That said, I'd recommend using the app to improve your tuning using the Sound Check feature - worked wonders for me.
