Dec 20, 2022 at 8:06 PM Post #49,487 of 70,071
I own them as of today.
General sentiment seems to be that the sound opens up and smoothens out after a bit of playtime. Keep at it chief! Put those hours in!
Dec 20, 2022 at 10:08 PM Post #49,489 of 70,071
Yes the Fiio Neckband is LDAC and the newer BT 5.2 and 5.3 options on Aliexpress with all the various connector types for your earbuds.
Sweet thanks! I’m definitely going to order mine. Luckily @erockg helped me to get the adapters for my Lolas which will work perfectly for this
Dec 20, 2022 at 10:16 PM Post #49,490 of 70,071
Yeah, saw it on their Instagram last night. Looks pretty cool. Might be worth checking out. I've used their bluetooth cables before and they're very nice. Had bought one for a pair of Etymotic buds a few years back before Ety came out with their OEM version.
I'm curious on how they will perform. It's odd that they don't come with charging cases.
Dec 20, 2022 at 10:34 PM Post #49,491 of 70,071
Yah, they don't really explain it on the site. Pretty sure they charge via usb on the adapters themselves. Not sure if they supply a split usb charging cable like the BT20s or the old FiiOs, but maybe.
Dec 20, 2022 at 10:37 PM Post #49,492 of 70,071
Dec 21, 2022 at 9:46 AM Post #49,494 of 70,071
Dec 21, 2022 at 2:49 PM Post #49,497 of 70,071
With 2 pins or even if they had 3 or 4 pins it would not be enough for Hybrid ANC for the Mics to do their job.
What mics?? Normal Iems don't have mics in them. Only ever in the cable. :) Only mic will be in the adapter body.
Dec 21, 2022 at 3:44 PM Post #49,499 of 70,071
Do you understand how the newer Hybrid ANC works unlike my older wired Bose QC 20's where the ANC/Battery were in a brick halfway down the cable.
Hint "feedforward and feedback microphones",
it is not going to work unless at least one mic is inside your ear.
