erockg
I haven't used my EX is a long time, but either I'm nuts (could be) or the ANC and Transparency sounds better. Using Azla tips.Updating now... no Release Notes.
I'm in the same camp as others that don't show an update as available but have 5.4 showing under "earlier releases".Updating now... no Release Notes.
This is for 5.4.9. Meaning, I just updated to 5.4.9 and no release notes. That said, I have seen the other fw update release notes.I'm in the same camp as others that don't show an update as available but have 5.4 showing under "earlier releases".
However, it does show release notes :-
Must be released in cycles, still havent received itThis is for 5.4.9. Meaning, I just updated to 5.4.9 and no release notes. That said, I have seen the other fw update release notes.
You’re in the walled garden of Apple, like me, right? How hampered are these buds on an iOS device?Any one find a good tip to use with the Galaxy Buds 2 Pro? Tried a bunch and wound up going back to stock. Causing an issue where if I wear them too long, they actually cause humidity build up of some sort and my ears are wet. Gross and frustrating. I'm reading it happens to some folks, like the first gen issue.
90% Apple here. Oddly enough, I have an iPhone and now a Fold 4. I set them up, and they do work great on my iPhone. Basic functions work great. Even without the iPhone you can still use anc, play pause etc., but you can't use vol control unless you activate the lab settings with an android device.You’re in the walled garden of Apple, like me, right? How hampered are these buds on an iOS device?
I've been using the Comply TrueGrip Pro Memory Foam Tips for the Sony WF-1000MX4 but work great for the Buds2 Pro. They do affect the sound slightly but it's a compromise I'm willing to make.Any one find a good tip to use with the Galaxy Buds 2 Pro? Tried a bunch and wound up going back to stock. Causing an issue where if I wear them too long, they actually cause humidity build up of some sort and my ears are wet. Gross and frustrating. I'm reading it happens to some folks, like the first gen issue.
Thanks. I was considering some Comply tips. Maybe better for ventilation. Great buds, but that on issue is annoying for me.I've been using the Comply TrueGrip Pro Memory Foam Tips for the Sony WF-1000MX4 but work great for the Buds2 Pro. They do affect the sound slightly but it's a compromise I'm willing to make.
https://www.amazon.co.uk/Comply-TrueGrip-Premium-Earphone-Wireless-Black/dp/B081QSLTW6
I don't like any of the stock tips, medium is the best fit for me but still lets in too much passive noise.
Does ANC matter to you? If yes and you are an iPhone user then I recommend the AirPod pro 2s without hesitation.I already have the AirPod Max which do the job for when you want to listen around the house, and are moving around with your iPhone in your pocket. Great on the plane. Have more expensive headphones that obviously have better sound quality.
I'm thinking of getting the AirPod Pro 2 when they come out next week. They won't be my primary IEMs or headphones, but will be convenient with no wires for the beach, walks around the park, etc. Any other premium wireless IEMs I should consider before getting the AirPod Pro 2? Sound quality wise, I know they won't be as good as high end wired IEMs, but decentish sound quality would still be nice. Mainly listen to rock and electronic/techno.
Mine arrived an hour ago. Same conclusion. The fit is killer. Anc is soul sucking. Sound remains very good. Nice upgrade.Bose QCII in the house. Wow. So much smaller it's wonderful. ANC is pretty pretty pretty good. Can't mess with them until later, but so far, not disappointed. One glaring omission is no wireless charging. No idea why they'd omit that from gen 2. Odd. Fit is perfect for me. The redesign is much better than gen 1. Happy camper for the moment.
Comparison pics vs the AirPods Pro 1 from Colorware that will probably be sold soon.
