https://www.jaybirdsport.com/nb-no/run-xt-true-wireless-headphones.html#985-000894
SBC, BT4.1... no thank you. I really hoped these would support BT5.0 and AAC.
This. So. Much. The significance of having BT 5.0 is so over played, it makes me nauseous.BT5 is nice but far from a dealbreaker. AFAIK the VModa Crossfades still use friggin' BT3 and it's aces both in connection and sound quality thanks to the codecs. If it's 4.1 then I don't think there's anything beyond maybe battery life or an occasional interference blip that anyone would notice.
@korefuji - same could be said about the codecs but in the end, everybody has specific needs. Maybe 5 isn't important to you given no range or connection or battery life issues but those can be requirements for others. Great we have so many choices no? ;o)
Just FYI, I was wondering if there is any way to confirm that my iPhone was connecting to various earphones using the AAC codec, and found (on this board) the following method to check the Bluetooth codecs and connection quality on an iPhone:
https://www.head-fi.org/threads/how...n-ios-device-and-bluetooth-headphones.835289/
Playing around with this, I found that the Sabbat E12’s and the Mifo o5’s (both of use, I believe, Realtek SOCs), apparently connect via AAC VBR at a maximum connection speed of 221 kbps:
“A2DP configured at 44.1 KHz. Codec: AAC-LC, VBR max: 221 kbps. 1 frames * (12+644) bytes = 656 per RTP (max=656) every 23.22 ms”
On the other hand, the MTW’s, the Mavin’s and the MPOW T5’s (all of which, I think, use Qualcomm chips), apparently connect via AAC VBR at a maximum connection speed of 256 kbps:
“A2DP configured at 44.1 KHz. Codec: AAC-LC, VBR max: 256 kbps. 1 frames * (12+744) bytes = 756 per RTP (max=879) every 23.22 ms”
(Note the numbers I’ve put in boldface.) Further, in all cases, a separate log entry indicated a connection rate that the actual connection speed bounced around (consistent with AAC VBR, I suppose) and more often than not was lower than 200. For example:
“A2DP LinkQualityReport: ReTx = 24.6% ( 14 / 57), TxPwr = 7 dBm, RSSI = -57, {50,75,90}th Noise = { -94, -93, -92} for 20 ch, 2EDR pkts = 26, rate = 192 kbps”
Before doing this, my assumption would have been that all iPhones connected via CBR AAC at 256 kbps — but apparently that assumption is wrong. I’m reluctant to correlate these numbers too directly with perceived audio quality, but I thought others might find these results interesting — and, perhaps, add to my understanding of what they mean.
I beg to disagree. MW07 is case in point. It has the cheapest Qualcomm SoC, the one even without a dedicated DAC, programmable EQ and updateable firmware. And still among current TWS they're one of the best sounding thanks, I suspect, to 10mm custom driver and sound (pun) acoustic engineering. In the end TWS, as any headphone, are most of all about acoustic design. I strongly believe that even lossless bitsream from the cleanest of sources won't make any headphone sound good if it has dismal driver or a badly designed acoustic path. But with good analog audio innards you can have well sounding TWS even if it supports only standard implementation of SBC over BT3 and a reasonable quality source in terms of mastering and bandwidth.Ah thanks, makes sense since the digital conversion happens inside of the wireless earphone and the quality over Bluetooth will not exceed the lossy transmission standard.
This must be why the more expensive TW buds generally sound better because of more costly DACs.
seems like ~10-25% of the posts in this megathread are simply repeats of previous posts by those who refuse to read back more than a few pages.1more is coming out with new TWS that they showed off in CES.
http://www.52audio.com/archives/13691.html
