Bhelpoori
Correct on the paper and the wireless part but the licensing situation has changed since then. Anyone with a Bluetooth SIG license to use Bluetooth audio can have LC3 up to 96/24. One of the reasons for that is that to maintain compatibility since LC3+ is effectively a different codec in that it needs different encode and decode, and the Bluetooth SIG didn’t want to see needless codec compatibility issues.The title of their own paper on LC3plus is "High Resolution via Bluetooth A2DP". It is BT and DECT and some other non-BT in addition. I don't think it is accurate saying LC3 is BT and LC3+ is not.
This quote would make no sense...
"LC3plus is the standardized solution to provide the quality of high-resolution music streaming services also over wireless accessories – facilitating independence from proprietary, vendor-specific technologies."
If they are not talking Qualcomm and Apple here and they mean to free us from non-BT vendor specific stuff I don't know what that would be. Please fill us in.
also..."bring high-transparency audio streaming to high-resolution wireless accessories such as headsets or loudspeakers. LC3plus is the only open-standard audio codec for high-resolution wireless headsets and high-quality gaming headsets."
Meaning these wireless devices mentioned here are not BT?? Think a majority of wireless and gaming headsets are BT, no??
Seems Plus is higher bit rate and considered Hi-Res and LC3 is lower bit rate and not as good. Not sure how they are the same. Not by how Fraunhofer are talking. They also have some balls with LC3 being free and you need to pay a license fee for plus. You would be paying for nothing if they were the same.
What is shown by this paper is that LC3 can be used with Bluetooth Classic aka A2DP rather than just LE Audio, although I don’t think that is standardised just yet, though haven’t checked for a while. It also shows that the biggest advantage of + is less latency, but that is constrained by how the Bluetooth radio works anyways.
LC3 isn’t free, it just has its cost included as part of the Bluetooth license.
For TWS, the biggest improvement is a standardised way for a TWS to work, rather than the mess of Bluetooth Classic today, and the ability to have high quality mic and audio at the same time, which is impossible under Classic. LC3 is a relatively minor part of the change, actually.
