Ceeluh7
Drivers settling, basically burn-in or listen-in. This set is so good man. So much clarity with a great stage for tws. Let's put it this way... I posted awhile back on this thread a comparison between the AKG and the Soundpeats Mini Pro and truthfully... There wasn't much difference at the time. I went back and forth a/bing them for awhile as the post was more about how impressive the Mini Pro were rather then a testament to the AKG. I wish I hadn't have posted that because about 20 hrs later of use with the AKG and they had opened up in the staging and there was better perceived resolution and clarity. It isn't some monumental change but in tws even small changes make a big difference. I honestly think the AKG are a fantastic iem for tws.What has improved “with use”? I have about 4 hours or so on mine so far probably.
And yes, the Harman tuned sound is definitely for me. For low volume listening it to me seems like a bit of a “loudness contour”. I think it would be a bit much at high volumes but I listen pretty low usually. With these and an iPhone I’m usually right at or just under half way up.
