erockg
Looks like the FiiO UTWS5 have an online update through the app now. Firmware 1.4. Not sure of the changes, but if I notice anything, I'll report back. Might just be 1.38 out of beta.
I have them both. The TW2 is finicky as far as fit, depending on what IEM you use. I'm rockin' those SeeAudio Midnight with them and I'm loving it. The UTWS5 accepts pretty much anything size-wise and fits great. The Shure adapters are just refined and work flawlessly. I've used both on calls, watched movies, etc. no issues. The UTWS5 can't be force paired like the TW2. So, I mean, depending on what IEM you want to use, you can't really go wrong with either IMO. Again, with the Shure, it'll depend on the size of the IEM, at least for me. Smaller IEMs on them fit me better. I prefer the Monarch MK2 on the FiiO over the Shure because they're bigger. Once you figure that out, they're both comfortable to me.Heard more about the UTSW5 over the TW2 recently. Is the preference the Fiio adapter nowadays? Is the Fiio as comfortable as the TW2 is? I am now back in the market for an adapter, but can wait until the UTSW5 pops back in if that is the hot item now
Also here and they often have 10% off coupon.I bought the MMCX model from Headphone Bar online in Canada. There is also Electronics for Less Canada that have it in stock in Canada.
Thanks bro. Might give a flyer on the TW2s then to see. I got the Technics TZ700s finally and they are uber small, so may just work outI have them both. The TW2 is finicky as far as fit, depending on what IEM you use. I'm rockin' those SeeAudio Midnight with them and I'm loving it. The UTWS5 accepts pretty much anything size-wise and fits great. The Shure adapters are just refined and work flawlessly. I've used both on calls, watched movies, etc. no issues. The UTWS5 can't be force paired like the TW2. So, I mean, depending on what IEM you want to use, you can't really go wrong with either IMO. Again, with the Shure, it'll depend on the size of the IEM, at least for me. Smaller IEMs on them fit me better. I prefer the Monarch MK2 on the FiiO over the Shure because they're bigger. Once you figure that out, they're both comfortable to me.
Looks like they should fit because they are MMCX. Just make sure you change what headphone you are using for them within the Shure app to account for power. I’m using the setting for the SE215 to power my SeeAudio Midnight.Thanks bro. Might give a flyer on the TW2s then to see. I got the Technics TZ700s finally and they are uber small, so may just work out
Going from the 3 to the 5 you will see a slightly wider stage and a more extended frequency both ways with more dynamics throughout. At first the difference isn't great but once the utws5 burns in a bit it does start to show. You get more power to drive your iems which aids the whole presentation. You get wireless charging, ambient mode as well. You would think the real benefit of the 5 is the extra power but imo it is the extra DAC which is the first of it's kind in an adapter set up like this (as far as I know) The 3 uses the DAC in the SOC whereas the 5 uses an independent AK DAC. The utws3 is fantastic and well well well worth the money they are asking but for the extra you'd pay for the 5 it is very much worth it...at least to me. Now as far as driving the Monarch or JH I think you would notice the difference, at least a little bit as those are both very resolving sets which would take advantage of the superior DAC chip. That said, I'm sure the 3 will sound great with either of those as well. Sorry if I didn't help you at all...lolSo… I wonder how much of an improvement in sound quality I’d see going from the -3 to -5 with Monarch or my JH Lolas?
reason I ask so that I have the -3 and I’m not sure when I’ll be able to find the -5 to order
Wow it sounds amazing. i love ambient mode on TWS. I’m stuck with the 3s until I can find a place to order the 5Going from the 3 to the 5 you will see a slightly wider stage and a more extended frequency both ways with more dynamics throughout. At first the difference isn't great but once the utws5 burns in a bit it does start to show. You get more power to drive your iems which aids the whole presentation. You get wireless charging, ambient mode as well. You would think the real benefit of the 5 is the extra power but imo it is the extra DAC which is the first of it's kind in an adapter set up like this. The 3 uses the DAC in the SOC whereas the 5 uses an independent AK DAC. The utws3 is fantastic and well well well worth the money they are asking but for the extra you'd pay for the 5 it is very much worth it...at least to me. Now as far as driving the Monarch or JH I think you would notice the difference, at least a little bit as those are both very resolving sets which would take advantage of the superior DAC chip. That said, I'm sure the 3 will sound great with either of those as well. Sorry if I didn't help you at all...lol
Thanks for letting people know about the update. I applied it and the ambient seems less artificial which is great. The assistant function now continues playing music versus pausing it. I did not notice any change in the music which is fine because it already sounds awesome.Looks like the FiiO UTWS5 have an online update through the app now. Firmware 1.4. Not sure of the changes, but if I notice anything, I'll report back. Might just be 1.38 out of beta.
I did see a used one in sale on ebay in the states for $104. Don't know where you live or if you'd go for a used pair. It is an mmcx versionWow it sounds amazing. i love ambient mode on TWS. I’m stuck with the 3s until I can find a place to order the 5
Agreed the ambient sounds a tad better. Glad Fiio sticking with updatesThanks for letting people know about the update. I applied it and the ambient seems less artificial which is great. The assistant function now continues playing music versus pausing it. I did not notice any change in the music which is fine because it already sound awesome.
No they will fit any mmcx. Just a universal mmcx adapterDoes the MMCX version require an adapter for non-FIIO IEMs? Most of the ones I use are MMCX but have had some of those fail over the years.
