Since you have been on this thread for a while, you should know how picky I can be about IEMs/TWS, and I was pleasantly surprised at how good they are at what they are targeted to be. It is a niche market for these, because everyone (except me) wants ANC or at the very least passive noise isolation. And battery life is less than the average of TWS nowadays, but from completely dead it only took about 30-40 minutes (didn't time it exactly) to charge to full in the case. Now, the case does take a long time to charge, so if you use these daily, you might have to throw the case on the charger nightly, but I do this with my phone anyhow.
With the proper fit and adjustment (these COMPLETELY rely on proper adjustment, or they sound like crap hence the mixed reviews on the sound) they are plenty loud to drown out all but the loudest sounds IMHO. And tapping pretty much anywhere on your jaw (it works best to tap your cheek where it is fleshy, the tighter the skin the less it will vibrate and the harder you have to tap) controls them, which is probably one of my favorite features aside from the sound quality.
This coming from someone who has NEVER liked any Sony IEMs or TWS to this point. Granted, I use the built-in EQ (Bright setting for more airy treble), the stock setting isn't as dark as their normal house sound IMO. Bass is plenty of quantity, but sub bass is severely lacking, so if you like EDM, or R&B, or Rap, these might not do it for you, though it isn't horrible on those either. But, with Jazz, Rock, etc... it has plenty; it relies on a boosted mid + upper bass to make up the lack of sub-bass.
