Ceeluh7
If you are broke, you may just want to get something like the kz az09 pro and buy a solid budget set like the. Cca Cra, KZ edx pro, eh there's too many to list. Anyways that is a route and I can tell you that the az09 pro is very serviceable and even sounds nice. Granted it isn't the utws5 or 3 but they are very good with a nice fit. Just a suggestion. That being said that utws3 is absolutely a great adapter man if that is the route you go. Let me know if you need help choosing some budget iems that are very goodOkay so y'all. If i'm getting a TW adapter, what is my best bet? Think I asked before but in a different matter.
I'm thinking that the Fiio UTWS5 sounds nice but it's not very easily accessible, but I can get the UTWS3, the Shure TW2 (slightly more pricy than I would like though) and the KZ AZ09/AZ10 maaaaybe the AZ09 Pro.
I'm probably not getting any IEM's just yet because I'm kinda broke as a joke, so i'm thinking of getting an adapter first and then bit by bit getting new IEM's, but I want the one that can drive the most IEM's without needing to be tampered with and so on. Feel like most of the IEM's I've looked at are MMCX but i'm not quite sure.
