Xinlisupreme
Fokus pro cost 130$ more than XM4, dunno if I’m going to pay it for it
That is quite alot to throw down on a set of tws. However the feedback from this group has been so very positive about them. I am debating about picking them up as well.Fokus pro cost 130$ more than XM4, dunno if I’m going to pay it for it
You mean Fokus Pro?That is quite alot to throw down on a set of tws. However the feedback from this group has been so very positive about them. I am debating about picking them up as well.
I have both. Fokus Pro definitely has more treble extension, which makes sense with hybrid configuration. Sony is good. New update added treble extension to my ears. If using for all purposes, Sony can handle more situations. I honestly love both, and plan to use the Sony for my workout iem now. I've loved Sony for the 4 months that I've had it though. Fokus Pro, XM4, Falcon Pro are 3 of my faves in that order. Falcon Pro when I want to hear more detail in instruments and treble, but the other two I absolutely like over the Falcon ProFokus pro cost 130$ more than XM4, dunno if I’m going to pay it for it
Everything is subjective in this hobby but that sounds like a good list.I have both. Fokus Pro definitely has more treble extension, which makes sense with hybrid configuration. Sony is good. New update added treble extension to my ears. If using for all purposes, Sony can handle more situations. I honestly love both, and plan to use the Sony for my workout iem now. I've loved Sony for the 4 months that I've had it though. Fokus Pro, XM4, Falcon Pro are 3 of my faves in that order. Falcon Pro when I want to hear more detail in instruments and treble, but the other two I absolutely like over the Falcon Pro
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
Maybe XM4 is warmer more L than Fokus that should be more on reference side, right?I have both. Fokus Pro definitely has more treble extension, which makes sense with hybrid configuration. Sony is good. New update added treble extension to my ears. If using for all purposes, Sony can handle more situations. I honestly love both, and plan to use the Sony for my workout iem now. I've loved Sony for the 4 months that I've had it though. Fokus Pro, XM4, Falcon Pro are 3 of my faves in that order. Falcon Pro when I want to hear more detail in instruments and treble, but the other two I absolutely like over the Falcon Pro
I definitely thought the XM4s were warmer and I actually let mine go in favor of the Fokus. Not sure if I’d call the Fokus more reference, but the imaging, soundstage and design alone is just wonderful. Most here know I highly recommend them. They’re my #1 TWS for sound right now.Maybe XM4 is warmer more L than Fokus that should be more on reference side, right?
Odds are very high you are right handed.
So what does that have to do with anything?
Audiologist see this a lot in the world of hearing aids. What happens when a right handed person bends over to tie their shoe, pick up an object etc, they rotate their neck towards the right shoulder as the right arm is being extended.
In the world of hearing aids, the microphone gets covered up & there is a rustling sound etc. In the world of tws, under the same scenereo, the right shoulder is essentially covering up the antenna and this can lead to brief cut outs.
Buying open box is always something to be nervous about.What you’re saying definitely goes along with what I’ve been seeing in my little experiments. But I have to say, I really hope that I just have a bad unit, because the pair I have are very very sensitive to interference. The right side cuts out a lot unless I’m just sitting still. I’ve own a fair amount of true wireless and I wear them all day long at work, and the only one that cut in and out a lot like these were the original Sony wf1000x. The other issue, that I didn’t mention earlier, is the right speaker doesn’t always connect when I first pull them out of the case and put them in my ear. After I put them back in the case and then try again, they work. These were an out of box purchase, so that might point to these being a bad unit. I hope that is the case, because I love everything else about them.
I bought them from audio46. I’ve been talking to Jim through email and I think that’s what I’m going to do. Thanks for answering back.Buying open box is always something to be nervous about.
I'd look into a replacement set, assuming you purchased them through an authorized source.
What do you have them paired with? You may have said already and I missed it.What you’re saying definitely goes along with what I’ve been seeing in my little experiments. But I have to say, I really hope that I just have a bad unit, because the pair I have are very very sensitive to interference. The right side cuts out a lot unless I’m just sitting still. I’ve own a fair amount of true wireless and I wear them all day long at work, and the only one that cut in and out a lot like these were the original Sony wf1000x. The other issue, that I didn’t mention earlier, is the right speaker doesn’t always connect when I first pull them out of the case and put them in my ear. After I put them back in the case and then try again, they work. These were an open box purchase, so that might point to these being a bad unit. I hope that is the case, because I love everything else about them.
I would say sometimes it happens, but I don’t completely agree that every time I tie my shoes I’m blocking a signal.What you’re saying definitely goes along with what I’ve been seeing in my little experiments. But I have to say, I really hope that I just have a bad unit, because the pair I have are very very sensitive to interference. The right side cuts out a lot unless I’m just sitting still. I’ve own a fair amount of true wireless and I wear them all day long at work, and the only one that cut in and out a lot like these were the original Sony wf1000x. The other issue, that I didn’t mention earlier, is the right speaker doesn’t always connect when I first pull them out of the case and put them in my ear. After I put them back in the case and then try again, they work. These were an open box purchase, so that might point to these being a bad unit. I hope that is the case, because I love everything else about them.
I have them paired with an iPhone 13 pro max.What do you have them paired with? You may have said already and I missed it.
