Thanks for your answer.I've experienced that noise before. I can't be sure but I think it's related to the Pressure Balance Architecture feature:
There used to be a fit test included in the app, but it was very finicky and I guess they cut it because of that. But what you are describing seems extreme. I would contact customer care, which is very responsive. They should be able to help you and maybe offer a replacement if necessary.
Yes it's extreme, and very strange.
ANC Low works quite well, especially with the Flexifit. Almost no noise with chewing/moving etc.
But with silicone and ANC High, it's extremely bad, and FAR worse with the left bud. (edit)
So strange that there no noise what so ever with Neutral (ANC OFF). With any type of tip too (I've tried almost 20 )
I will go to the store, try one of their demos and maybe let them try mine (if they want, hygienics etc.. )
I also sent a message to Devialet support.
Thanks again.
