Aug 30, 2021 at 9:47 PM Post #36,796 of 70,766
It’s the middle of the night, I’ll try to make a close up tomorrow (today 😳) with better light.
Let’s say you if you swipe with the finger on the backside of the case there is no edge noticeable. If I do it on the right side of the front there is one and a much stronger one on the left side of the front.
Mine seem even after looking closer at the case. Did you ever get any better pics of what is going on?
Aug 30, 2021 at 9:51 PM Post #36,797 of 70,766
I noticed the same. Can almost watch the percent disappear :D
Been emailing with Devialet support about battery expectations. They said should get 4 hours with ANC on. I said Im lucky to get that with ANC off. To wit they said:
“…we are working on a firmware update to solve this battery issue which should be available in last quarter of the year.”
Aug 30, 2021 at 9:54 PM Post #36,798 of 70,766
I used the ePros and Finals and cannot seem to replicate it using both usual (far right just up from energetic) and high treble settings. Will continue to listen, but I have to turn the treble down a bit as I think my ears are bleeding a little :D
Let me know what songs and I’ll try too. I heard it a few times when I first put the ePros on and now I can’t figure out what song. At first I thought the ANC mic had something to do with it. Searching…
Aug 30, 2021 at 9:55 PM Post #36,799 of 70,766
4? Their site says 6. lol
Aug 30, 2021 at 9:55 PM Post #36,801 of 70,766
Never a dull moment. Sigh…
Aug 30, 2021 at 9:56 PM Post #36,802 of 70,766
Try 1000 July's - Third Eye Blind. Perhaps its a crap recording?
Aug 30, 2021 at 9:57 PM Post #36,803 of 70,766
You might be right. Best I could find today even close to thinking what I heard was around the 1 minute mark of Scorpions Unplugged Athens - Big City Nights on the drum beat. But that is reaching pretty hard I think. Let me try some settings on and off to see if I can find it. Before it was definitely on Scorpions Unplugged or Florence and the Machine Unplugged albums.
Aug 30, 2021 at 10:06 PM Post #36,807 of 70,766
If you use the included MT wings, you may actually have the small mics blocked by the rubber sleeve. The holes in those sleeves to accommodate the mics are very small and the alignment doesn’t have to be far off. I may try enlarging the holes.
Thank you! I'll check it out and I really hope that's what it is as I'm using the wings.
I took a few calls using the MT and was unable to carry a conversation and when switched to the Fiil people were commented that I sounded perfect - all calls were indoors.
Aug 30, 2021 at 10:16 PM Post #36,808 of 70,766
Listened to that with Adaptive off/on. Around 1:50 in I heard something which I guess could be it, also at the very end of the song it was a bit scratchy so hard to tell but maybe I guess. Have you guys made any correlation to listening time to when it happened? I think I was listening a couple hours in when I heard it initially. Wonder if something is warming up and degrading?
Aug 30, 2021 at 10:16 PM Post #36,809 of 70,766
$27.50 (pretax)…ridiculous!! Couldn’t pass it up to at least try them.
Indeed, awesome deal.
They are super comfortable and very well made and their app while not perfect is very good and a rare sight to have an app for such a cheap set of TWS.
Another interesting thing is that the app has the Burn-In feature which is basically 3000 minutes of pink noise played according to their process in different levels.
Now, not to start a debate here if burn-in is legit or if it's simply "brain-in", I was running it for the Fiil CC2 and the sound seems to changed a little after about 500 minutes of it, so maybe there is something to it.
Aug 30, 2021 at 10:36 PM Post #36,810 of 70,766
It was toward the end. I'll get you guys a time on the track tomorrow for confirmation. I heard it on a few other tracks as well.
