The other MMCX-2pin adapters finally showed up. For the BT adapter crew out there, figured it'd help if you saw a size comparison:
There's definitely a reason you're paying more for smaller connectors. Build quality is not comparable and it really shows in the amount of extra space the cheaper adatpers require. Those OEs are deceptively small and it translates to a fantastic experience with the CF01. Not factoring in the length of the pins, they're literally half the size. Makes a huge difference in where the IEM falls in your ear, but having both types will allow me to tweak the fit of each IEM to my liking.
