BenKatz
First thing I did when I received the xm3 is to change the settings... Been using a lot of sony bluetooth speakers / headphones, dsee is not a secret to me. And I didn't say the resolution of the xm3 is the worst in the realm of tws. But it's average or below even in the tws world, and for people like me that favor resolution/listen to complex music, it's unbearable.
To give you an example, nural n6pro which is also a pair of tws, has much better resolution than the xm3.
And also like I said, music files make ton of difference, if most of the time you are listening to pop songs thru spotify I can see why it's hard for you to tell the difference.
Yeah, I more than completely disagree. If your assement of the XM3 is that the rewolution of the XM3 is "average or below even in the TWS world", I'm now 100% sure your pair was defective.
As I said, I compared them to the TWS Technics AZ70, Sennheiser Momentum 2, in-ear wired Campfire Audio Polaris v2, Sony XBA-N1a, and the XM3 came definitely on top of the TWS, and very competitive in some aspects (some better, some worse) than the wired high-end-ish ones.
And Idk what you are listening to, but you definitely don't kno what I'm listenin to I don't even use spotify, I use tidal, and no, I don't listen to POP, so you needn't worry about the "music file" differences.
Trust me, as I said before, considering the overwhelming number of reviews and comparisons of the XM3 online, (even disregarding mine which is quite extensive), saying that the XM3 have "trash" resolution or are below average even for TWS truly does mean that you have had a defective model.
