Technics case is still charging, but the buds are good to go for now. Running them on ANC at first and with no other adjustments to try to get a good initial impression on them. Here's what I've got:
These are, without a doubt, built with materials worthy of their asking price. Everything feels nice to the touch. Nothing creaks. It just feels dense. I approve. Have mixed feelings about the little L/R nub they put on each bud, but I imagine that's to help you figure out which ear is which without having to look.
Setup was equally easy; only the JBLs so far set up easier and that's because you have to first take the Technics out of their case for initial pairing (with the JBLs, you don't). Even the firmware update, though somewhat long, effortlessly worked. So far, so good. Hey, that case is still charging...I hope that's not going to be a regular problem, but I guess I can just leave them to charge overnight.
Technics even manages to carry the design language of the buds into their app. Hard to explain, but it's intuitive and well-designed. Still not finding a fault here.
How do they sound? They're not too shabby. At first listen, they're considerably bass-light compared to, say the MTs, but then you realize no one range seems to play above the other. In that sense, the AZ70W might be unapologetically neutral. Pretty cool that the Bass Boost has a very limited band, adding to impact without the bloat. Does collapse the stage a bit, though.
I can tell these are going to be a pair you have to sit with and get used to. The UEs were the same way. They're definitely not consumer-tuned and they won't hide any recording blemishes (admittedly, the UEs can mask bad recordings just a little better). Sometimes, that's exactly what I'm looking for.
