Going fully Wireless IEMs. Too soon? Or are we there yet?
- Thread starter webreaper
Hi, I hope everyone is doing well.
I usually renew my TWS IEM’s every year and it’s time for doing that now. For 3-4 days, I’ve been searching for a new one, and found several options which are Tronsmart Spunky Beat, Tronsmart Spunky Pro, Haylou GT1 Plus, KZ S1 and Wavefun Xpods 3. I have a price range of 20-25$. For now, Tronsmart Spunky Beat is my first choice here since I think it’s more likely to satisfy my expectations. I’ve heard that it’s well balanced but still I’m not sure because I want plenty of punch and kicking drums (but not like a bass bomb thing) and I wonder if there’s any IEMs which I don’t know in this price range and better than Spunky Beat.
By the way, I’ve owned QCY T2C and Blitzwolf FYE-7 before and didn’t like both.
I’m waiting for your recommendations and thanks in advance for the help.
Note: I like Apple EarPods’ general shape of sound, maybe it helps to compare with.
HiddenUser
It seems that little by little more TWS earbuds supporting aptX Adaptive are appearing. The last ones are Xiaomi Mi Air Pro 2 and Soundpeats H1. This is interesting, because aptX Adaptive is backwards compatible with aptX HD (and also standard aptX), so earbuds with this codec can receive aptX HD or Adaptive data from another device.
Since there are very few wireless IEMs supporting both aptX Low Latency and HD/Adaptive (I have only found the H1 and the Creative Aurvana Trio Wireless neckband), could you recommend any other TWS earbuds (not neckband) supporting both aptX Low Latency and Adaptive?
Thanks
Thanks
helmutcheese
- Feb 13, 2014
- Messages
- 99
- Reaction score
- 40
^^ SoundPeats Sonic also.
AFAIK it does not have as low a latency as aptX-LL @ 40ms but will connect to aptX-LL devices as backwards compatible..
Overall it has latency of 50-80ms (adapting between quality and signal strength/distance/source content) which is lower than before for aptX and aptX-HD.
HiddenUser
Are you sure aptX Adaptive is backwards compatible with aptX LL too? That is, can a device transmit LL data to earbuds supporting ONLY the Adaptive codec and still get the lowest latency supported by the Adaptive codec (50ms)? The Qualcomm site claims that Adaptive is only compatible with aptX HD and aptX... My guess is the LL data is converted to standard aptX, so high latency is unavoidable in this case.AFAIK it does not have as low a latency as aptX-LL @ 40ms but will connect to aptX-LL devices as backwards compatible..
Thanks again
PS. I can't find the Sonic. Even is not advertised on the Soundpeats site (the new H1 is).
smith
- Aug 5, 2004
- Messages
- 589
- Reaction score
- 48
Hope they get a UK release....
[which QUOTE="jant71, post: 15994132, member: 22616"]
Got a delivery from Amazon a few minutes ago. My last TWS till the new wave come with 5.2 and LC3+. Took some quick pics.
size comparison with some not all
Off to test them out a little.
First take is very positive. On all fronts actually. Like the case. Happy with the improvement over my JVC on the hear through and mic quality improvement. Sound impresses with the size and space, the bass reach, the resolution, and the space and roominess of the sound. No smear or congestion and you can hear everything in it's own space. Love the small size and easy fit and comfort. A little push and twist seems to be the right way to insert quick and easy. Case is small and solid and type C just no Qi. Quick solid connection, perfect touch controls. Easy enough to grab them on the sides and never accidentally touch the panel. Can get quite loud so not close to max volume on my devices. Can't think of anything negative to say.
[/QUOTE]
[/QUOTE]
The Apostle
Hoping to get some feedback and suggestions. I m looking for a new pair of TWS that will be used on conference calls, that at times, is a slightly noisy office. Currently I switch back and forth between the Jabra Elite 65t and Plantronics Voyager 6200. Both have their pluses and minuses and I am probably tying to fill an unattainable voided. Nonetheless, here I am. LOL. Here is what I am looking for and how the current handle those situations.
The Elite 65t pick up everything in the background. The call quality is good from what everyone says, but I always get asked what's going on in the background. These things pick up everything!
If I can find something that works I am not concerned with the price. Does anyone have experience with conference calls in variable environments that can make suggestions?
- ANC
- Ability to turn off hear through
- Won't overly pick up background noise
- A good seal (none of this new proprietary weird oval crap)
- Companion app for adjustability
helmutcheese
- Feb 13, 2014
- Messages
- 99
- Reaction score
- 40
From my readings yes if a receiver only had 1 codec and that was aptX-LL it would still connect to it and play but will not be 40ms.Are you sure aptX Adaptive is backwards compatible with aptX LL too? That is, can a device transmit LL data to earbuds supporting ONLY the Adaptive codec and still get the lowest latency supported by the Adaptive codec (50ms)? The Qualcomm site claims that Adaptive is only compatible with aptX HD and aptX... My guess is the LL data is converted to standard aptX, so high latency is unavoidable in this case.
Thanks again
I am not sure if it will use the original aptX as that is what happens if you connect an aptX only device to an aptx-LL only device (but any LL device will normally have aptX also so both codecs).
Look at my posted history, I posted the Sonics last week and updated the other day but so far they are on Ebay.com (I am in UK) so I ordered them directly from SoundsPeats China via Ebay.com.
Ordered on the 17th and they are now with the Royal Mail (sat at customs a few days due to Covid etc) so will be here on 27th, not too bad.
SoundPEATS Sonic Bluetooth 5.2 True Wireless Earphone CVC 8.0 Noise Cancellation | eBay
Blotto80
I haven’t really been paying much attention to the TWS space of late but now my kid wants a pair for Xmas but her main use is video (YouTube, tiktok, Netflix). Is there anything cheap that has decent latency with an iPhone? I’m less concerned about SQ than price and lag.
HiddenUser
I was asking the opposite: when the receiver only has the Adaptive codec and receives LL data from a device (typical scenario for the H1). This is important for watching TV with negligible lag (I'm sensitive to this). As you know, there are very few Bluetooth transmitters supporting aptX Adaptive (you have to buy a BT DAC/amp). Most mainstream transmitter/receivers support aptX LL like mine (and other codecs too, but not the new one). Anyway, I have read some reviews and it seems the H1 has a special gaming mode. According to the manufacturer, the lag in this mode is very low - 40ms. approx, virtually the same as that of the old Low Latency codec. But take this with a grain of salt, because a reviewer measured 175ms latency with this mode on (high in my opinion).From my readings yes if a receiver only had 1 codec and that was aptX-LL it would still connect to it and play but will not be 40ms.
When it arrives, please comment on your first impressions.Ordered on the 17th and they are now with the Royal Mail (sat at customs a few days due to Covid etc) so will be here on 27th, not too bad.
chinmie
as far as i know almost all TWS, even the cheaper ones would have a good low latency on IOS devices for videos, so the choices would be plenty. you might also consider form and sizes that would fit her better, also whether she prefer open seal or IEM styled TWSI haven’t really been paying much attention to the TWS space of late but now my kid wants a pair for Xmas but her main use is video (YouTube, tiktok, Netflix). Is there anything cheap that has decent latency with an iPhone? I’m less concerned about SQ than price and lag.
helmutcheese
- Feb 13, 2014
- Messages
- 99
- Reaction score
- 40
I do not know of any transmitters with aptX-Adaptive so far, only ear/headphones.
I seen a good review on the H1's and the gaming mode was down to 50ms dependant on what device it was connected to and what the content playing was, obviously they fair better with Android devices than Apple.
He had a GUI on the screen and yes in one use it was a 3 figured read out.
It was on Youtube recently so will be one of newer one as there are not many reviews.
The Sonic also has gaming mode.
Here : The VERY BEST of 2020! - Soundpeats H1 Review + Latency & Call Test - YouTube
chinmie
there's a new review of the Soundpeats Sonic on YouTube
seeing the form factor, it might be better fit for smaller ears. it's already available on my local online market, but i still more intrigued to try the H1 more
Klipsch T5 II are 50% off for Black Friday right now on Amazon. Love mine! Klipsch T5 II True Wireless Gunmetal
