Sorry to hear. Seems like we just have different preferences. I personally started using them on Treble Boost then briefly on the Clear Setting. I am now using them on Normal. Based on your EQ setting preferences, I think we just have different tastes and, as many others have said here, it may just be differences in fit, expectations or simply personal preference. For overall comfort/fit and convenience (what I look for in TWS) the Galaxy Buds Live have replaced my Senn MTWs and MW07 Go, both of which I rarely use now. While the MTW and MW07 Go certainly have better SQ to my ears. I prefer IEMs with passive isolation for when I really care about SQ and use my SE846 instead.
The Galaxy Buds Live have been fantastic for calls (my main use case) and I use them for calls a few hours every day. I was just noting that I was pleasantly surprised at how great they were for the commute to my office in NYC.
I think there is a general misunderstanding of what ANC is supposed to do on the Galaxy Buds Live. They are an open design and they will not be able to block outside noises like IEMs with good isolation do. ANC basically helps filter out low frequency sounds but you will still be able to hear people around you (or your music playing on speakers). It made a very noticeable difference for me for the noise from the train's HVAC system. As I noted in my last post, I could still hear the announcements so I would not miss my stop but it did eliminate most of the fan noise. I also sit right next to a fairly large 15000 BTU PTAC unit in my room and it made a noticeable difference for me when the unit was running. Again, it is open so it cannot block out all the external noise but I think it does what it was meant to do. Your mileage may vary.
