I am using Levantree DG60 V.1 that outputs 24 bit / 48 kHz AptXHD from PC, which BTR5 receives. The latter is super light, clips to my shirt and with IEM cable also tucked in for me it is (almost) as portable and comfortable as a TWS, with the advantage you can use your favorite wired IEM and stream at 24 bit. PM me if you want more info since you are correct, strictly speaking this isn't a TWS solution and thus is off-topic.Ah dammit. I’ll look into these Levantree devices. I want as good of a fully wireless solution as possible. A high quality transmitter feeding high quality true wireless IEMs
Going fully Wireless IEMs. Too soon? Or are we there yet?
- Thread starter webreaper
tgx78
Member of the Trade: tgxear
Does anyone know if the n400 supports aptX?
I think I will wait to see what the impressions are for the n10 pro and definitely pick between the two... probably
or maybe the Klipsh T5 II...
arrrggghhh... too many choices..l
I don’t think the n400 supports aptx. Sbc & aac only.
So many options.L3s are okay. The IBasso IT00 are cheaper and better imo and you can pair em with the IBasso CF01 TWS adapter for an iem true wireless solution.
L3s are fine for classical, very safe tuning. Solid timbre.
Also thinking of getting the L5 when they arrive in Germany. Probably mid October.
jant71
- Feb 19, 2005
I pre-ordered the new Cleer Goal in black...
Saw the original price of $129 was dropped so they were $99.99 @B&H. Got enough sealed in-ear stuff and no worries about ambient footfall noise etc. In addition to the lower price they added some battery to the original spec. 6 hours still but now three full charges for 18 more in the case with 5 minute for 1 hour quick charge. They have aptX, IPX5 now up from IPX4 at CES announcement. Auto pause resume on both sides, 4 silicone skins S,M,L wings and no wing. Customizable touch controls and EQ etc. with use of the app. 13.4mm drivers. USB C but not wireless charging which is the only thing I feel is missing for a situational awareness sports bud. At the lower price I was okay with no wireless charging so it obviously didn't deter me from ordering.
Caipirina
- May 25, 2015
Yeah, missing support document / video on HOW TO GET THEM!Buds live sleeves. Hope it becomes available in other countries too.
https://www.samsung.com/us/support/tip/TIP00087482/
Great News, I'd like to mention a couple of things.Hi,
Apollo Bold APP will release next week! In the end of this month! We are testing now.
1. If it doesn't have Customizable EQ, a Firmware update tool and Button Customization, DON'T RELEASE IT UNTIL IT DOES. Presets, suck! For me the only mode I can currently use for audio is OFF.
2. It takes 3-4 seconds to cycle between modes, when you are around people and need to switch modes, it's MUCH quicker to take them out, then to have to wait for the voice prompt and the device to switch. There needs to be an option to turn off the voice prompts and speed up the Cycle, like on the Sony XM3's.
3. Something needs to be done about the touch sensors, maybe I have a bad pair, but I have to tap at the bottom half of the earbud to get it to recognize and unless they are deliberate, like almost forceful taps the don't always register.
I can't seem to find any info about these, I see them at B&H, but there's no photo, info etc. Could you provide a link?
helmutcheese
https://www.h1.soundpeatsaudio.com/
Still have not going to learnt 6hr per charge is not great today.
how much is the soundpeats H1? specs looks great with 8.6mm DD + 1 Knowles BA
No clue, you need to sign up for early deal.
jant71
- Feb 19, 2005
Best source is probably the manual... https://fccid.io/2ATS9-1313/Users-Manual/15-GOAL-UserMan-4815066I can't seem to find any info about these, I see them at B&H, but there's no photo, info etc. Could you provide a link?
Cleers latest(they just put info up today... https://cleeraudio.com/in-ear-headphones/goal/
And pics way back around CES time...
jasonb
- Sep 14, 2010
I have them coming in 3-5 business days. I contacted them via the online chat and asked for them and they are sending them out to me. It was a long slow conversation, but it went well. I've always kind of had issues with consistent fit, and maybe this will fix that. Or it could possibly make them seal better and bloat the bass even more. We'll see soon I guess.
helmutcheese
Listen to Bluetooth’s low power, high quality LC3 codec coming soon to headphones
Listen to Bluetooth’s low power, high quality LC3 codec coming soon to headphones - The Verge (theverge.com)
Here is another I use:
Bluetooth A2DP SBC/aptX Online Encoder (valdikss.org.ru)
AudioNoob
- Jan 9, 2004
It would be good if one could also 1) choose the default anc mode when you take it out of the case 2) disable one of the three cases so that you can cycle between two of your choice.Great News, I'd like to mention a couple of things.
Thanks, nice find.Anyone else find this little hidden gem in iOS14? It’s very deep within settings>accessibility>AirPods> Headphone accommodations> Transparency mode. As if the transparency mode on the AirPods Pro wasn’t good enough, now you can boost them to a superhuman level, make them brighter or darker and pan L or R.
It didn't just help with transparency mode, but with the sound quality as well.
Try the "Custom Audio Setup". When getting to the Music section I use Version 2 in Comparison 1 and Version 1 for Comparison 2 and 3.
You get a little brighter sound with higher amount of details, clarity and definately a little more open/airy sound as well. (edit: You can get it even brighter with setting Version 2 on the other Comparisons too, but I found that to be too much)
Thanks
I actually just set mine manually in the headphone audio. The custom audio setup is just a wizard that helps you determine which of the 3 settings and their volume levels you prefer, it's not a custom eq per say. You can adjust it in the Tune Audio For: section. I use the brightness setting on slight (normal volume). It's much better for me, but the dumb air pods still don't have any bass.Thanks, nice find.
You get a little brighter sound with higher amount of details, clarity and definitely a little more open/airy sound as well. (edit: You can get it even brighter with setting Version 2 on the other Comparisons too, but I found that to be too much)
Thanks
I hear noticable difference by using the setting I described.I actually just set mine manually in the headphone audio. The custom audio setup is just a wizard that helps you determine which of the 3 settings and their volume levels you prefer, it's not a custom eq per say. You can adjust it in the Tune Audio For: section. I use the brightness setting on slight (normal volume). It's much better for me, but the dumb air pods still don't have any bass.
The Brightness setting is too bright for me.
Bass? I think they have plenty bass (I use the large Comply tips)
Is the fit test green?
