Decided to skip the whole TWS craze and stick with wired Chi-Fi iems (and over-ear BT cans) till I suddenly got annoyed by the heat and wires (working from home). No idea why I didn't give this a shot before.
Looked at a graphs to see what sound signature I might prefer and got the Samsung GBuds+ (a week ago) and now the Tevi (today).
Quick takeaways:
- Samsung's engineering is amazing. The GBuds+ are clearly the better package physically (got the BestBuy aura blues and they're sexy).
- The GBuds+ touch controls are far easier to use than the Tevi's tactile buttons. Not the biggest deal to me since I almost never use them.
- Samsung is really turning into the next Apple. The lack of Apt-X and locking SBC at 37 (out of 53) Bitpool is clearly to force users into their proprietary codec (and their phones). Basically ensures that unless you own a Samsung device, the Buds+ are a non-starter.
- Apt-X vs bad SBC is instantly noticeable! I didn't think it would be so clearly noticeable. Seems that Windows 10 will connect via Apt-X as long as you have a 4.0+ dongle (even if it's not Apt-X certified).
- They both have pretty similar sound signature (because that's what I was looking for). I prefer the Gbuds+ (on clear) but the difference isn't significant enough to pick one over the other. I'd say the Tevis come out on top with their app (equalizer). They just need to get it on iOS. The Tevis seem like the GBuds+ on Dynamic.
- Both very comfortable and easy to get a seal. However, the Tevis are 1.5g lighter and definitely feel lighter (noticed the weight difference and weighed them).
- The Tevis have better range and a better microphone by far. Not even CLOSE. However, the Tevi only has one mic between the two pairs which is kind of an odd choice.
- Samsung's case is so much smaller but the Tevis give you much more of a recharge (22 vs 70). I'd say it's a wash. Both last around 10 hours so battery life is a wash.
- Tevis don't have audio passthrough but I never bother with that. Something to keep in mind if you use it.
- One major win for the GBuds+ is that you don't need to disconnect from one device to connect to the other. Connect from your new device and they jump right over.
I think Samsung made a real miss-step with their codec choices (see #2). For $60 less, it's a real conundrum as to which one goes back. Leaning towards keeping the Tevi at the moment (as the majority of my use is with a Windows machine and iPhone). I think Apt-X would have made the GBuds+ a no brainer (total shame).
I'll probably stop here and wait for what BT 5.2 will bring. Very excited about the future of TWS. I don't have a wired pair with me to compare but the convenience is definitely worth whatever hit there is in audio quality I think.
GBuds+ Codecs:
Tevi Codecs:
