Got the Buds+ yesterday and have been using them extensively for the last 24hrs; thanks to
@jkjk123 for selling me his new pair! Very lengthy writeup below!
Sound preferences are highly opinionated, so here's some context:
I love and prefer neutral sound, probably on the brighter side. (mostly listen to everything on my JBL LSR305 reference monitors, and the FLC 8S which...I lost in March on a flight. Loved/used them for some years *cries*. Initially used gold/red? filters for that oomph, but later switched it up to gray/gray? for neutrality iirc. I also owned/went through the GR06/GR07/GR07BE, which is a sound signature I adore (as most do).
I value separation, detail, and clarity above all, and I prefer something that will do everything equally well over something singular like heavy-hitting/clean bass. I listen to all genres, but mostly a lot of electronic music which have all types of instruments/vocals and covers the full frequency spectrum in a single track/mix/set, which should explain my preferences.
I've had a cheap BT Aukey and Anker beater $25 pairs for the gym -- surprisingly the Anker Soundbuds Slim+ have been the most comfortable set I've ever worn (strangely that's now one of my benchmarks for comfort) Fidue A83, probably worst.
First TWE I've owned, picked after extensive research. Haven't had the chance to really listen to other TWEs yet, unfortunately (maybe fortunately).
Here's my first 24 hour Buds+ journey:
Initial impressions: light in ear, great battery life to mitigate dead-earphone-anxiety, compact. Magnets are weak, if you drop it on anything solid a few feet in the air, the case can open then close in an instant while buds fly out. I read someone lost them first day because without noticing, so be aware! Ambient mode I can see being very useful, but is treble heavy/unnatural/robotic sounding. The 4 levels of ambient volume levels is super nice (with the extra loud option in the labs. It's neat, but maybe gimmicky. Like superhuman levels of hearing lol).
Audio BT/lag issues:
Also, I had audio lag issues while watching Youtube/videos on Windows 10 (out of sync voice/lip). Thought these were unusable at first. Was already on the latest firmware update. Not sure if it just fixed itself later via proper codec negotiation, or if I got used to it, or cause I did this possible fix, or all of the above but they seem ok now:
https://www.reddit.com/r/galaxybuds/comments/b4vx3c/audio_delay_with_windows_10_laptop/ermyv0y/
If someone wants me to test them with games like FPS, holler at me - too lazy lol.
(I had some very slight/short BT audio dropouts with my laptop (Matebook X Pro 2018, Win10) from a distance (5-10 feet away). I think it may be the laptop, as my Pixel 1 (yes 1) is completely fine.
First listen, sound quality, did not like at all:
Initially, I was very disappointed with the sound quality. Thought maybe all the online reviewers didn't know what they were talking about. Maybe they aren't audiophile material, consumer oriented, etc. etc. Ugh!
1. Tried the medium tips. Wasn't getting a good seal, immediately switched to large tips. (I normally wear medium, and switched back to medium -- more on this below).
2. Normal EQ sounded flat, everything sort of muddled together. Very bleh, thought they were horrible.
3. Turned on Dynamic EQ like many suggest and prefer
Crinacle says the Buds+ sound like "bitcrush" and that's probably a good description, but he didn't say what EQ he was using. I thought it was maybe just bluetooth compression, but prob nah.
So on Dynamic EQ: Voice by itself in e.g. Youtube was clean. But with music, a different story. Lows by itself was heavy-hitting, satisfying, and clean (imo the Buds+ does this *extremely well*, among the best I've heard). But I felt that it lifts/pronounces the low and high ends
_too much_ to the detriment of the mids. Probably enjoyable for the average consumers.
I don't think soundstage is a strength on these. Made worse with the (great) bass/sub-bass creeping into the mids. I think that might be why it sounded compressed and unpleasant to me -- I wasn't satisfied at all. Also I can definitely see how they can be fatiguing on dynamic mode, though I didn't find it too much of a deal (I do prefer brightness). So I switched back to Normal EQ for a bit, which probably after my ears adjusted, wasn't as bad as my initial impression, but still bad. Went back to Dynamic, tried out Clear EQ very briefly was alright, didn't think much of it (more on this below!) Fell asleep with them in my ears.
Next day I tried them out, my opinions didn't change. So I tip rolled -- went through a bunch of old silicone tips I have from who knows where. My opinion is that double-flange and foam tips are best because they have the highest chance for a good seal, but unfortunately they don't allow the Buds+ to fit in the charging case or work well with the wingtips. Could try cutting or getting shallow fit foam tips, but it's easy to get a good seal with silicone tips on the Buds+:
Tip rolling and mastering fit:
Initially the fit hurt with the large Samsung tips, and I was having a bit of discomfort. I learned how to properly fit these to my ears: the large size tips were providing a good seal, but didn't allow the Buds+ to go deeper into my canal. So I switched back to medium sized tips, which allowed me to really push them further into my canals and lock the wing-tip below that thing-that-sticks-out-of-your ear (I will call it "ear-thing").
I also read somewhere on Reddit of discomfort and that it helps to instead of sticking them in with the wingtips above your "ear thing", then rotating them to your rear to lock them in,
try to start with the wingtips below the "ear thing", insert into ear, then rotate them towards my front until they lock into ear. They're very secure, none of that iem slowly creeping out of your ear when you chew/move etc. Take off shirt, no big deal, flick them with a finger, no big deal. Probably will get used to it in a couple days like I've read (when it gets softer, or my ears callus? :/) I also tried softening the wingtips with my fingers.
Tip on experimental/lab side tap volume adjustment
I couldn't figure out the experimental/lab feature to tap the side to adjust volume up/down. Until I had the proper wing-tip locked into ear position -- now I find works very well (works on both phone and Win10!). The trick is to give a semi-forceful, downwards tap (twice) at the top edge of the buds. Like if the buds were a joystick sticking out of your ear.
Eventually settled on these tips (no idea where they're from). Compared to the stock Samsung tips, you can see that the nozzle is a lot bigger --
seems to help open the sound, slight improvement. I prefer them. Not sure why the Samsung tips have such a small hole, that doesn't match the size of the Buds nozzle? Maybe to keep earwax out? (Left is stock Samsung, right is I have no idea where from):
Spent today listening to music, then started listening to a dnb (drum and bass) mix with vocals (which I think is a good overall litmus test for my preferences. Tests bass, many different types of sounds, fast-paced, plus male and female vocals. Again, on Dynamic EQ, lows were amazing, highs were good, but overall it just sounded off -- the mids. Really imo ruins the whole package, and wasn't giving me that "I want to keep listening to this music" feeling. Semi-fatiguing.
The major saving grace to Buds+ sound quality, imo:
Buuuuuut I had read a single comment on all of the internet about Dynamic EQ great for original Buds but too much for Buds+, and someone using the Clear EQ for Buds+. And this EQ is my saving grace for the Buds+, rounding out the entire journey. I find it strikes a nice balance between normal and dynamic. Extra clarity (obviously) brings out that needed sparkle that Normal EQ lacks. Bass isn't as satisfying, but still very good, allowing the mids to breathe. Bass boost, Treble boost, and Soft EQs imo don't even bother, they don't fix the problems, just exaggerate.
I wish Samsung provided a fully customizable EQ in the Wear app. Thankfully the EQ presets stick to the Buds+ across devices. I was semi-interested in Jabra 75T for this, also for multipoint (which I've read mixed reviews on), but I've gotten the impression that Jabra's durability/QC isn't great. (read the online reviews regarding hardware/software issues on both the 65T and 75T audio-hiss, etc.).
Also, (really trying to make myself not try the 75T haha) the battery of the Buds+ seems like it can be replaced fairly easily:
https://www.ifixit.com/Teardown/Samsung+Galaxy+Buds++Teardown/132702
Whereas the 75T (seems like you have to physically cut the housing) and maybe others won't be so easy. Definitely a concern for me with the longevity of TWEs.
65T:
https://electronics360.globalspec.com/article/13996/teardown-jabra-elite-65t
75T:
https://fccid.io/BCE-OTE120/Internal-Photos/Internal-photographs-1-of-2-4477902
TL;DR: Was disappointed, almost threw in the towel with the Buds+. Thankfully a mixture of tip rolling, proper fit semi-unique to the Buds/+, probably ears adjusting, and most of all Clear EQ saved it. Really give it a chance!
