Chrisdu18e
Nothing, no hiss, no noise....for those that have tried the senn's, any sense of background his, power noise or anything like that?
The left earbud is slave.The right earbud consume more batteryDoes anybody else with the Sennheiser TW find the right earbud drains quite a bit faster than the left?
I thought there was no primary, that they connect via a magnetic field.
I have RHA incoming. After seeing your views, i wonder if i should have waited and bought sennheiser insteadSo my Sennheisers TW came today, they're pretty good.
Have had a busy day, not much time - but here are my quick impressions:
The case is okay, not as premium feeling as the RHA one. Open/close mechanism actually feels cheap / plasticy. I think the LED light is 3x colour stage so that's fine for battery indication.
Earbuds are extremely comfortable, fantastic fit.
I think there is a good deal of Bass. I wouldn't say it was flat, more bass-heavy..... If anyone says they're light on bass well they must be "bass-heads".
The clarity overall is great, I'm going to keep them and return the RHAs.
EQ is pretty basic, I'd use another app instead to play around with it. Gestures are okay, and when you remove the right earbud it pauses the music 80% of the time. Swipe gestures to change song would've been better than tapping.
They get very loud - the headphones/phone have separate volume levels. That reviewer who said they were quiet obviously didn't test them properly.
I think the battery life will be more than 3h, haven't tested the charging time yet.
Yes, I'm seeing the same from checking the App, between 5-6% more than the left.
I actually return the senn in favor of my earins m2
Sennheiser TW charge time is either rapid, or incorrect. In 5 minutes the earbuds went from 39% > 78%
So first impressions are:
- case is a little bit flimsy. Not sure how the hinge will hold up
- touch controls work 80% of the time, one too many commands to remember
- app is quite basic and you can't seem to change the name of the device
- the right side tends to drain more battery
- its all about the fit for best sound quality. the included tips are a bit shallow. i'd buy 3rd party ones
Good stuff:
- probably the widest sound stage for a TWS I have encountered, waiting to try the MW07
- clean, accurate sound. my beatsx is a bit more energetic though, but nowhere as capable as these
- love the size of it, so small and looks elegant
- no hiss nor background sound
- no video lag at all, tried various video apps, incl. youtube, netflix etc.
- very stable bluetooth connection, no lags, drop-outs etc.
Want to try the MW07 as many people are raving about the sound quality. Will update more as the units get used more and 'break-in'.
Some pics:
You'll see that a lot in the TW that do the "fifteen minutes gives you an hour and a half" thing. It'll spike up hard really quickly but then stabilize a good chunk lower than that. The MW07 will go from a warning beep to 100% in like ten minutes but ten minutes after that it's at 60% and drains normally from there.
