jant71
- Feb 19, 2005
I would prefer a $1000 TOTL TWS iem. Because these devices are so easy to carry and use. And unlike traditional IEMs, no need for a dac, amp and cable. Just buy a TWS IEM and use it with your smartphone, endgame !
If someone makes a TWS IEM sounding good as current audiophile wired earphones that can be revolutionary.
They(the higher end brands) only offer the option to plug in to a BT cable. We are talking multi-armatures, up to double digit drivers so no room. The expensive dynamics also wouldn't sound near as good if you crammed up a bunch of stuff inside their housings. They will resist trying to solve all the issues that comes with an all in one solution so you are gonna get more of the Ionic SE215, Fostex TM2, Fiio/TRN style solution to plug the $1000 plus earphones into. We are just waiting for better versions of this type.
