TedB
The base price of the Dayzee is $1300. Unless there is a discount by having Geshelli do it, swapping in (8) single SS2590s will add another $600 to the bill.
Yes, a little bit strange, that all eight opamps must be replaced:The base price of the Dayzee is $1300. Unless there is a discount by having Geshelli do it, swapping in (8) single SS2590s will add another $600 to the bill.
True, but it seems the Dayzee will be in a whole other league (in both sound and price).A great advantage of the J2S in comparison to the new Dayzee seems to be that it is possible to make the upgrade to the SS2590 for the RCA only for example.
According to feedback from Geshelli with the Dayzee all eight opamps must be replaced.
It’s a totally different topology. Almost not able to compare the two. They’re built to be doing different things. The Dayzee is very much a digital hub for many devices. Yes they can use the same opamps but the topology and implementation of the opamps and dac chips are what creates the sonic experience. Look at it this way, the two options of the J2S have different dac chips and similar topology yet they sound different. The Dayzee is a completely different dac with a completely different layout so foundationally it will be a different experience. It was designed to be a completely different experience.Yes, a little bit strange, that all eight opamps must be replaced:
https://www.head-fi.org/threads/dayzee-flagship-dac-from-geshelli-labs.972083/page-2#post-18051539
Then the Dayzee is around 2k......., so the J2S with SS2590 might be a better VFM
I am curious how it will compare to Schiit Yggi and Audio-GD DACs in the same price range.It was designed to be a completely different experience.
What advantage does using a linear power supply provide? Which one would you recommend?Not knowing more than the basics at this point, the Dayzee appears to address the more upscale aesthetic experience many asked from the J2 platform. Whereas the J2 is an austere, pure "meat and potatoes" DAC that emphasizes hardware and implementation over aesthetics, and that makes it a great value in sonic performance, the Dayzee provides the nice large case, fancy display, and greater connectivity many find attractive, albeit at much greater cost.
Both the J2S and Dayzee use the same AKM 4499EX+4191 chipset although the Dayzee specs imply that it employs "dual mono" AK 4499EX sets. And as mentioned, the Dayzee uses an individual mono op amp and socket for each channel instead of stacked mono (dual) units. Because Geshelli authorizes the top op amp option for the J2S to be the SS3602, the Dayzee with SS2590s presesnts an upgrade above the best official version of the J2S.
The aesthetic and connectivity upgrades the Dayzee brings for those who want more of a living room visual piece are clear, but whether there is anything to be gained sonically above a "hacked" J2S with SS2590s and LPS - upgrades not authorized by Geshelli, remains in question at this time.
Still... It is unnecessarily, silly huge. Geno wanted to pitch this at me just before he started showing it off. I don't like it. He admittedly needs to upgrade his setup to move into tighter, smaller more refined PCB layouts.True, but it seems the Dayzee will be in a whole other league (in both sound and price).
Agreed, it is larger than it "needs" to be. Can't imagine when I will ever have a chance to hear one, anyway. (BTW, my replacement half of a SS2590 should be here in a few days. Will sand down the boards and try to make it fit my older J2S.)Still... It is unnecessarily, silly huge. Geno wanted to pitch this at me just before he started showing it off. I don't like it. He admittedly needs to upgrade his setup to move into tighter, smaller more refined PCB layouts.
All true. But know that many engineers design their products and build the sound around the common switch mode power supplies that come with the products. I have for sure heard some improvement from going to a linear power supply but nothing worth spending more than one or two hundred on. Never ever be fooled by marketing and the hifi chat room or reviewer video hype to think that your product will sound bad with the switch mode power supply. Again, lots of the time the engineers design them around those. I know Geshelli does and Robb Watts the engineer behind the wild Chord products has been quoted many times saying he does the same and he personally uses the switch mode power supplies that come with his products. Is there a difference in switching to a linear power supply, yup! There is for sure. Are the products, especially the Geshelli products still crazy amazing with the included switch mode power supply, absolutely 1000% yes.Digital audio devices like DACs and streamers tend to be sensitive to noisy switch mode power supplies (SMPS), which most know as "wall warts." These are inexpensive and allow manufacturers to keep costs in check, although they tend to impact sound quality to some extent. This isn't an issue for the average consumer with inexpensive gear, but it does become more of a concern with better, more resolving setups and more discriminating listeners. Two options that can significantly improve the quality of the DC power feed to sensitive devices include the iFi iPowerX , which is a SMPS with active filtering to deal with the noise, or a suitable linear power supply (LPS) with good regulation and filtering that eliminates the noisy switching circuit altogether. Many have noted audible improvements when upgrading the power supply for DACs and streamers, significantly so with certain devices, so it's something to consider.
I agree. I love the idea of what they're doing here with the Dayzee but it seems that it's very much a niche product. Great for a few set ups but not for everyone. In emailing with them they've told me that it sounds amazing but it's a bit of a waste of money if I am not connecting it to multiple sources because of all the outputs that come on it. What I think Geno needs to do is cut down the analog outputs on the Dayzee to make it for maybe 2 amps, that's far more common for the every day HIFI enthusiast. Still make the dac topology as wild as the Dayzee, still make it a big step up from the J2 dacs. I love my J2 Geshelli stack. That will be forever on my desk. I'll keep it for ever and ever. But it would be way cool to see what they can make that's like 2/3 of the way to the Dayzee. Like a Dayzee for normal consumers.Still... It is unnecessarily, silly huge. Geno wanted to pitch this at me just before he started showing it off. I don't like it. He admittedly needs to upgrade his setup to move into tighter, smaller more refined PCB layouts.
I'd bet its as big as the Dayzee needs to be but not many people actually need the dayzee. I don't know that I know anyone I can think of that have all the amps on hand connected that need all the analog outputs the Dayzee offers.Agreed, it is larger than it "needs" to be. Can't imagine when I will ever have a chance to hear one, anyway. (BTW, my replacement half of a SS2590 should be here in a few days. Will sand down the boards and try to make it fit my older J2S.)
Look at the bigger post I just listed that describes my experiences with linear power supplies vs other options. It might add some clarity to your question there.What advantage does using a linear power supply provide? Which one would you recommend?
Heck, My J2S has more inputs than I need! Geshelli makes the USB optional but forces us to pay for two SPDIFs and two toslinks for no good reason. Could have been even more of a bargain if those front panel inputs were optional! HOWEVER, at its price, it's too good a deal for me to be complaining about too many inputsI agree. I love the idea of what they're doing here with the Dayzee but it seems that it's very much a niche product. Great for a few set ups but not for everyone. In emailing with them they've told me that it sounds amazing but it's a bit of a waste of money if I am not connecting it to multiple sources because of all the outputs that come on it. What I think Geno needs to do is cut down the analog outputs on the Dayzee to make it for maybe 2 amps, that's far more common for the every day HIFI enthusiast. Still make the dac topology as wild as the Dayzee, still make it a big step up from the J2 dacs. I love my J2 Geshelli stack. That will be forever on my desk. I'll keep it for ever and ever. But it would be way cool to see what they can make that's like 2/3 of the way to the Dayzee. Like a Dayzee for normal consumers.
