tmaxx123
- Dec 5, 2012
Really appreciate the tips! The ifi seems like the easy choice but I’ll keep researching. I don’t like to settle
Just got the pulse infinity from Amazon, was purchased during the recent price drop. Went into it with extremely low expectations and was hoping to return it after reading everything about it. After listening last night for over 8 hours straight , I am blown away. At first , figuring out how to hook it up to my pc, was a bit of a hassle. But basically you only need one driver (usb 2.0) from windows. My pc hates the lightspeed 2.0 cable though. Had to use a standard one. Now I’m using it in host mode off my iPod and listening to onkyo hf player and iTunes on it. Sounds incredible. Rca outputs are running to a sub stage amp and that signal is clean and strong. Hopefully the pulse holds up and doesn’t randomly poop out on me!!! Can anyone recommend a lps for it? Or is the lh labs lps the best one for it?
I feel the same about my XFI, it does DSD really well, a pleasure to listen to.
You don’t happen to use a lps or any aftermarket power supply do you?
Happy New Year!
I don't have a USB type C to male USB B cable unfortunately.Mice, try usb via OTG on your smartphone if it works.
I used to have one but it broke.Even Type C OTG (USB A) + Printer Cable?
Welp, I think my X Infinity's USB input is dead. I plug in headphones and all I hear is a brrrrrrrrrrr sound and no audio plays back. Flashed the latest version of the firmware, reinstalled the latest Windows drivers, nothing. Turned off/on the unit, nothing. Tried using it with OS X, nothing. Restarted all computers and tried plugging it in, nothing. Tried a different USB cable, nothing. Tried other USB ports, nothing.
Plug in my PS4 via TOSLINK, and magically it works.
Seems like just a random failure. It was working just fine last week. :/Wow that sucks! What do you think may have caused it? Or was it Just random failure?
