jexby
- May 29, 2013
Why isn't the LPS feeding clean USB to the Pulse?!
The Pulse can operate without the LPS using a switched power supply. The USB can run from a computer (USB A) to the LPS (USB B) and then from the LPS (USB A) to the Pulse (USB B). This does not give power to the Pulse but it completes the handshake (5V) from a computer to the Pulse. Running through the LPS is supposed to clean/filter the USB signal and improve sound quality. Note that the LPS cannot be used with a Geek Out when wired in that fashion.
Axel,
EXACTLY the answer I was expecting! this usb-reconnect is what we were trying to accomplish at RMAF table, but were missing a second USB cable.
I hope the reviewer actually uses the LPS to feed USB to the Pulse as you mention (and unplug the GeekOut for now), to help discern the overall impact of Pulse Xfi with AND without the LPS (for power AND USB).
Lucky I have a spare Lightwave USB cable around here......
Wouldn't the optimal setup be Computer > Lightspeed 10G > LPS > Lightspeed 1G > Pulse? You'd at least be maximizing the transfer between the computer and LPS before dropping in quality. The other way around just seems like overkill to me.
I'll give both ways a try Brian. Either way we have massive bandwidth to play with.
Not to power the Pulse, just to filter the USB. I use it form PC to DACs. Although GO450 doesn't like it.
Hmmm, I wonder why GO450 doesn't like it?
Yes it should work fine in filtering the power to the Pulse.
