Tzuky
- Feb 25, 2017
Thank you Eujin, you are correct for the difficult of finding "before" "after" sound... For now I will ceep this configuration.. In the futureI might take your advice and change some off these capacitors for a bit bigger ones as you did. And for the record i could notfind any schematic eather... At least we know with upgrading capacitors the device will live longer than with the cheap and probably fake original capacitors
