MrSlim
Member of the Trade
- Oct 31, 2007
I think I found the solution to the "going mobile" problem!
http://www.ebay.com/itm/like/281229007052
It's basically a 1 port USB hub. I'll update when they arrive (from China), but I think I should be able to trick my phone (iPhone 5S) into talking to the Fulla.
/Battery or 5v power
The chain will be: iPhone---CCK---Comfast---Y cable---
\Fulla
We, considering it's only ~10$, there's not much to loose, but with the shortage of information online about how it works, I'm more than a little suspect. If there isn't another power source then the current draw (the real problem here) from the source USB port is still going to be the same. There is no way it can it can boost the current for the 5V line provided beyond what the originating USB port is willing to provide. I think what it might be is a line driver or repeater that will boost(ie regenerate the bits) the data signal lines, for long cables, using the built in 5V power.
If that is the case, then it will not help.
