roadtonowhere08
- Mar 6, 2004
Got myself three (all different addys and names of course)!!! W00T!! Thanks KR...!!!
Originally Posted by aeriyn I drove my brother crazy doing this when I went to visit him last year. ![]() |
Originally Posted by Reck45 schick quattro razors are horrible, I've never been cut up so bad while shaving. ![]() |
Originally Posted by stevesurf Yup, my GFs daughter or someone else (!)keeps borrowing my vibrating razor (Gillette). Geez you know it right away...but it's too late...you wind up looking like you were attacked or something. I used to just shave in the car on the way to work (don't worry not while driving), but the new goatee has me spending more time in front of a mirror. I felt like a dumbass, all I had to do was just keep buying her new razors ![]() |
Originally Posted by remilard Their privacy policy says that if you opt-in they may share your personal information with their advertising partners. If you don't opt-in they only use it for internal purposes. |
Originally Posted by viator122 I received one before Christmas in the mail for no reason, apparently. I was disappointed: the replacement blades are very expensive, the blades go dull very fast, and I didn't find the shave with a fresh blade really any better than the Mach 3. I don't even find that the Mach 3 is that much better than the Sensor, so I just stick to that since it's cheaper. But then again, I'm not a hairy ape-man. ![]() |
Originally Posted by 450 I don't shave yet...so just wondering...what's the big deal about the different type of razors ![]() How expensive are these things? Wouldn't it make more sense to get an electric shaver at 70-120? |
Originally Posted by viator122 Well the big deal is that you're talking about a piece of steel that you are going to use to drag across the skin on your face and cut all the little hairs off. If the razor is dull, it will give you lots of little tiny cuts. Some types give people skin irritation, etc. You want a razor that will give you a close, clean shave so that when you go to work, or go out at night or whatever, you look nice. Also, the blades can be expensive: 12 Mach 3 cartridges go for almost $22 (typical wisdom dictates that you use a cartridge/blade for 5 shaves), so everyone wants to make sure they get their money's worth. I don't know that much about electric razors; I haven't had one in probably 10 years. When I did, though, I remember that the shave was not nearly as close as with a blade. I should add that I have a hot lather machine made by Conair. You stick a can of shaving foam in it and plug it in. It heats the shaving cream in a minute or two to give you hot lather like the barber shop uses. I find it helps me get a closer shave with fewer nicks and cuts. It goes for $16 at Amazon. |
