Rufus_Truthfist
- Nov 26, 2008
has anyone else tried this?
Originally Posted by Trapper31 /img/forum/go_quote.gif After days and days of searching for a headset or headphone/mic combo I have finally decided to go with the AD700s and this mod. In the beginning I was held back because I'll be using this with a PS3 and you need a USB (or Bluetooth) mic for that. Sooo, after more research, I found that this 3.5 to USB adapter will work for the mic. Thanks to Fragtality and everyone else here for the heaps of great information and advice! Kool Bubba Ice's gaming guide was particularly helpful as well. |
Originally Posted by Astropin /img/forum/go_quote.gif I plan on doing the same mod as the original poster and will be using it on the PS3. The downside of your fix (the 3.5 to USB adapter) is that it still does not allow you to adjust the game & chat volumes on the fly. So for that I will be using the Astro Mixamp. That gives you the complete package. Great headphones for gaming, a good mic & the ability to adjust the game and chat volume. Not to mention that it adds Dolby Headphone (if you don't already have it through your receiver). An absolute must for FPS's, or any game where you want directional sound indications. |
Originally Posted by xformulax /img/forum/go_quote.gif |
Originally Posted by YiP /img/forum/go_quote.gif Great paint job, looks a lot more appealing with the black grills instead of the stock purple. I'm thinking of painting mine too. Did you remove the badge when you painted them or did you just cover them with some tape? |
Originally Posted by xformulax /img/forum/go_quote.gif sorry, i didnt notice the question before, i removed the AT tags, they're held on by 2 sided tape and i pushed them with a pin from behind, you have to be careful as the adhesive is pretty good and the metal they're made from is very thin, i bent one but i was able to bend it back and reshape it, it's not perfect but it looks fine.... i still wouldnt chance trying to tape it up, maybe try heating the adhesive with a heat gun or a hair dryer would help it come off easier? i'm not sure how paint would stick to the purple, but of course you can try it... i decided to strip mine first because i kind of wanted them to be silver.... turned out i liked flat black better though. |
