Fungus
- Feb 16, 2011
I already have these pads, just haven't had the time to ibstall it. I've heard without the rings, the sonic qualities are reduced? Any knowledge of this?
Do you have a massdrop version of pads or the TH-900 ear pads that can be bought from Dekoni web site?I already have these pads, just haven't had the time to ibstall it. I've heard without the rings, the sonic qualities are reduced? Any knowledge of this?
according to the graphs provided by @cskippy yes. The best pads are massdrop dekoni sheepskin (the best I mean the most flat one)So the Dekoni sheepskin pads made specifically for the X00 as marked on the box are the only pads that will maintain a similar tuning to stock?
there are Dekoni TH-900 ear pads and they fit X00 but they are changing stock sound. Look at the graph on the top of the page - green and blue are Dekoni TH-900 ear pads (that can be purchased directly from Dekoni) while red is massdrop dekoni X00 padsSo you mean to say there are non mass-drop dekoni sheepskin pads out there?
The only connector that will fit without cutting/drilling and will not stick out like the SMC connectors that I know of is the MMCX connector but the MMCX does not have a twist lock and was designed for and primarily used on IEMs. They are used on Shure headphones but these connectors are not very secure and are easily damaged from my limited experience with them on my SRH-1840. I've tried them on my SennGrado also but quickly changed them out for SMC connectors.So the Dekoni sheepskin pads made specifically for the X00 as marked on the box are the only pads that will maintain a similar tuning to stock?
I also wonder if there's anyone in the headfi community that knows how to install detachable connectors like on the TH610. There are so many detachable connector options out there at the moment that I don't even know which is best. I've heard some mods causes the cups to sit further out increasing the gap or even involves drilling a hole on the inside of the cup. I'm looking for a connector that utilizes a twist to lock mechanism and doesn't stick out the hifman SMC style connectors.
