As @Phantaminum noted the same questions keep coming up on all threads, such as "what is the best amp for _______" "what is the best upgrade cable", or "how to get the most out of __________ headphone". All these repeat questions might be avoided if the search function were easier to use but then again it doesn't seem to work on my system.I’m Just curious....does anyone read anymore?
Same questions over and over again with post upon post with answers. Lol
@chimney189 , the TH-X00 can be sibilant/harsh for some and it will also depend on your current gear (DAC/amp), genre of choice, source files, how loud you listen, etc. If the LCD-2.2 has as much treble as you can handle then I wouldn't suggest any TH-X00 models but it you sometimes wish for a bit more sparkle in the highs then I'd say give the TH-X00 a consideration, note that some like me find the stock ear pads very uncomfortable and many of the suggested pads are $50 to $80 and they will affect the sound signature, as to if the effect is good or bad depends on the individual. I don't have much experience with the Lawton mods that many talk about but on a friend's TH-900 with driver damping mod only it a really nice overall sound but even then its not something I can use every day, just too much bass for some genres of music IMO. I do have a TH-600 and LCD-2f, have heard the LCD-2.2, LCD-3f and a few others, I've sold the TH-X00 mahogany, just to give you an idea of what I've heard.
