Skipshrike
- Aug 3, 2013
TH-X00 vs.
- Beyerdynamic DT-770/880/990: Less treble for sure. Beyond that, I haven't heard any of those for a couple years.
- Fidelio, Grado: No idea because I've heard but never owned them.
The clarity and soundstage are quite good for a closed can.
The frequency response is kinda like if you pushed down treble above 5kHz and bass below ~300-400Hz by 4-6dB.
There's still color and character to the headphone and you can tell they're made by Foster Electronics for sure, they're just less colored than the predecessors.
Bass is impactful and extended, but not as impactful as the TH600/TH900 with the default sound signature. Treble has air, but not glare. The low mid suckout is not nearly as pronounced, and mids in general are more forward since the bass and treble are less prominent.
The pads are not the same as TH600/TH900 pads, and unfortuantely I don't have any of those on hand to try out. For most people, they'll be big enough. My ears are tall and they don't fit inside.
HM5 pads will fit nicely, as with Lawton and Alpha pads. Audeze pads are slightly big but do fit as well.
Compared to the JVC HP-DX1000, I'm not yet prepared to say I prefer the Fostex TH-X00. I'll have to burn them in and and listen quite a bit more to be sure.
I do prefer them to the TH600.
You might wonder why, given that I'm a basshead.
The reason is that I like the entire frequency response stock, and the reduced treble is huge for me because I'm sensitive to treble.
Since I am indeed a basshead, I use EQ and/or hardware bass boost when I want extra bass with all of my headphones. The TH-X00 has the same bass potential as its brethren despite having reduced stock bass.
Because of that and the beauty of the cups, this is my favorite Foster-made headphone I've ever heard.
If this sounds near the JVC HP-DX1000's then I'm hooked. I heard those and they were amazing.
