modded with new cable + XLR plug + Lawton Mod ! (the tuning Kit N°1)
Fostex TH900 mods
- Thread starter zolkis
Matvei
- Nov 14, 2013
Does anyone have the service manual for these? Or can tell me how you replace the leather handband
Christoph
Have you now found the ideal damping amount and position? Some posts ago you weren't complete happy with the damping mod.modded with new cable + XLR plug + Lawton Mod ! (the tuning Kit N°1)
AT Khan
- Nov 3, 2015
Yes I need this too. If you find a way, do let me know as well.Does anyone have the service manual for these? Or can tell me how you replace the leather handband
well. I gave up, and now my TH900 is back to his box...
omegaorgun
Previously known as FireLion
Th900 mk2 connector part numbers! Has anyone ever modded a MK1 or TH600 etc?
JSBachFan
Formerly known as K400Lover
- Aug 4, 2014
I own two MK1 and one MK2. I just ordered the materials in order to mod them all.Th900 mk2 connector part numbers! Has anyone ever modded a MK1 or TH600 etc?
Just not sure I will be able to get the right "wolfelt" in "wit". Contacted the company to see if they are willing to send it to Germany.
Why would MK1 be a different mod than MK2? Are they not build the same except for the replacable cable?
I never opened mine so far.
JSBachFan
- Aug 4, 2014
PS: I am planning to do zolkies mod.Th900 mk2 connector part numbers! Has anyone ever modded a MK1 or TH600 etc?
I compared TH900 to DT1990 for a while. In the end I do Iike the TH900s still way more, but now I am unhappy with the recessed mids. It is just too recessed. The mids are reproduced way better on the DT1990. But all the rest is better on TH900. Musicality is about on the same level. I sucessfully did some equalizer tweaking (levels down a bit on both ends in a certain way) but I don't want to use an equalizer. So now a mod has to do the trick (hopefully).
jmills8
Previously known as bmiamihk, jmills2
If you bring the mids forwards then you will have less bass and less treble.PS: I am planning to do zolkies mod.
omegaorgun
Would be worth getting the Dekoni attenuation ring to retain the bass and test different pads. I had the TH900 pads on my TH610 and wasnt a fan, liked the shape but not the material. I alwasy meant to get the lambskin TH900 pad. Lambskin should bring back the highs a little.
Currently I am using the modded Stax 009 pads on the TH900 as well as on the D9200.
I still have all the other pads, but I feel the Stax pads sound the most natural and cleanest.
If you want slightly thicker pads, the same mod applies to the Stax 007 pads and they are slightly cheaper.
These lambskin pads will outlast other (non-leather) pads several times, so actually they are good value as well.
JSBachFan
- Aug 4, 2014
I am aware of that. This is what I already "achieved" manually via the equalizer settings. First tried to increase the mids. But it was an awful result on the FiiO M15. Reducing highs and bass a bit on the other hand didn't ruin the overall sound. The musicality staid pretty much the same and the mids indeed came forward a bit.If you bring the mids forwards then you will have less bass and less treble.
The result was good enough for the decision to send back the DT1990. But it took a while (one week of intensive comparing) and inbetween I was pretty unhappy and even put two of my TH900 pairs for sale. Voices just sounded so unnatural in comparision to the ones on the DT1990 that I coultn't stand it any more.
I once bought these lambskin pads (praised here sometimes). But for me the musicality worsened and that is my top priority in sound preference. So I don't use them.
Still unhappy I found this thread here. My hope lies on the mods now.
JSBachFan
- Aug 4, 2014
Are you saying I should try your mod on my (at the moment not used) lambskin pads immediately?Currently I am using the modded Stax 009 pads on the TH900 as well as on the D9200.
Does it match with the your mod from page 4 since lambskin will also change the sound characteristics?
I actually love my TH900s so much, I will do everything to make them work for me again by "repairing" the recessed mids ...
JSBachFan
- Aug 4, 2014
I own three pairs of used TH900 ( ...before they were at home and two different work places. Now they are in one place due to for some time permanent home office).
Trying to find out which pads are the best to be modified with the mod from zolkies, I found these pades the best sounding ones. Actually to a level, that I will definitely not mod these in order to be able to compare them to a mod on original stock pads. I did try them on the different TH900, but the effect of the pads are stronger than the difference in cables or mk1 vs. mk2.
I bought them all used, so I have no idea, what company produced them. They are for sure not the original pads.
I was searching a bit. The only simiilar looking ones are from Geekria. But they don't look exactly the same.
Can anybody here help me finding out, where these pads are from? They might smell like leather a bit. Maybe it is leather.
Could they be Dekoni LCD pads?
