I wanted to offer a thanks to all people involved in this project. I'm not done, but I just crossed from 'OK' to "Wow!'.
I'm powering the Fostex using a tweaked Panda with 0Ohm output resistance and +3db gain. At home I use a Macbook Pro into a Gamma 1/2 DAC; at work I use an iPhone 5 into a reconfigured grubDAC. My reference headphone is a Lawton L2 Denon AHD2000.
I'm sure it has been done a thousand times before, but here is my mod history and impressions:
T50RP, Stock - Uncomfortable, sensitive to ear position, and all mid-range. Moving on...
T50RP, SRH840 pads - Pads are a touch warm, isolate well, and are much more comfortable than stock. The lows and highs start start to come in, but frequency balance is still mid-heavy.
T50RP, SRH840 pads, RiteAid cotton balls (6 per cup), 1x3mm base port, closed baffle port - Further refinement to the low/high frequencies. While the bass is not big, it is going low. The highs are playing from behind a veil. Overall decent, but the bass is not "fun" and the highs do not sparkle.
T50RP, SRH840 pads, RiteAid cotton balls (6 per cup), 1x3mm base port, closed baffle port, Silverstone in floor wells, ~10g Newplast mass loading - The Silverstone caused a severe sensitivity drop. The bass may have improved, but it is merely there. The veil over the highs is even more pronounced. Don't stay here.
T50RP, SRH840 pads, RiteAid cotton balls (6 per cup), 1x3mm base port, open baffle port, Silverstone in floor wells, ~10g Newplast mass loading - No perceptible change.
T50RP, SRH840 pads, RiteAid cotton balls (6 per cup), 1x3mm base port, open baffle port, Silverstone in floor wells, Creatology adhesive felt in top/bottom of cup, ~10g Newplast mass loading, 19mm treble reflector (shiny magazine cover), 45x52mm (w/ 4x3mm bass holes) Creatology stiffened craft felt over driver - The highs have snapped into place; the bass tight, low, and fairly balanced with the rest of the frequency range. At this point, these cans are no longer decent but quite impressive.
Aesthetic/comfort mods:
V-MODA cable - Hey, the static is gone!
MrSpeakers Leather Comfort Strap - Oh so comfortable! No more headband hotspots!
Next up:
I have Dynamat ready to go around the ear side of the drivers. I also plan on swapping the cotton balls for fiberglass/rolled cotton.
I have REW at home, as well as the Panasonic mics, however I have not built my power supply yet. Eventually I will measure my build and continue to tweak.
