bluemonkeyflyer
- Jan 20, 2011
I uploaded 6 new graphs to the database: BMF DBV #2, a slight variation to BMF DBV #1.
The greatest source of info on modding T50s for sure. Big thanks to you BMF!
Insane extension on the DBV 2!
The only thing I did not really get about the mod is about cup bass ports: Are they completely closed or completely open (only felt cover)?
Those DBV2 measurements are insane! That's about the flattest FR graph I've seen -- Kudos! I'm going to have to crack mine open again and give this a shot. What kind of fiberglass are you using -- just standard home insulation? Hopefully this new version will be added to the wiki soon though you've detailed here quite well. Thanks Keith!!
Man, This Thread ROCKS...
Thank you sooooooo much.
Jim
BMF,
If i understand correctly, your measurements show the blocked ear canal response for your ears. Are you using any compensation EQ in these measurement (to account for a free-field or diffuse-field type of response at your ear)? Can you explain your reasoning for using or not using a specific compensation scheme?
BMF,
BMF,
