Longfellow78
- Feb 8, 2014
Thanks for the quick and comprehensive post. I had the mayflower baffles on my t60rp (which I sold). Yes the bass was very bloated but the argons also have sealed front ports and so do all mk2s but don't have that bloat. I wonder if the different paper on the back of the driver makes it have more bass to compensate but the open ports allow more breathing.Youve got a lot going on in that post. So many variables.
1. Velour pads can be tricky. Its a breathable material that could create new complications depending on the foam used inside the pads. The foam inside would need to be closed-cell or of very low air flow to maintain characteristic sound of non-permeable pad materials like leather.
I tried the Shure pads with Mayflower mod on a T50RPmk3. Did not care for the sound of Mayflower nor the comfort of Shure. Mayflower mod uses a custom foam that essentially seals the front-side vents underneath the pads. This leads to a very warm + bassy signature. The Shure pads are also on the smaller side and I didnt like the feel of the fabric material.
Im a big fan of the T60RP pads. I like the sound and feel. T60RP pads are thin but not so thin as to be supraaural which effects sound and comfort.
Tuning to taste is part of what makes modding worthwhile. Cant be sure what mod to recommend to you exactly because dont know your hrtf, preferences, average spls, upstream gear, music, etc.
You know T50RPmk4 is about to drop. Maybe just wait a bit as it may be completely “better” than mk3.
Anyway. I'm thinking as I'm after mid bass and mids and some treble sparkle, but less bass I should keep those ports open. The shure pads I assume are quality but who knows. I am OK with the t60 pads but I was guessing they would mill limit the sound stage.
I am very unsure what damping the backside of the baffles does, nor covering the frontisde with felt. The argons are widely regarded as the best t50/60 mod but have no clay damping on the back of the baffles and nor do the mad dogs. Everyone seems to do this but to my knowledge this comes from the mayflower mod which is not even that highly regarded....
