joe75
- Aug 19, 2009
Yep, I just checked my battery case tonight and it has lost 1 lev3l bar out of 4 and it was fully charged yesterday.From earlier discussion it was mentioned that they stay in standby for a while so you can reconnect them quickly if needed. I mainly use earphones just to listen to music, so when I'm done I put them back in the charging case and that is it. If the TWS/1 is not switching from a 'standby' mode and shutting down while in the charging case then that is a problem and I hope a firmware update can fix it.
Yesterday I .just opened case once and closed It and did not even listen to them.
And i also purposedly used the Grell no more than 10 minutes today...so according to my calculations.
In less than 4 days and with less than 40 minutes total listening time, both cases and buds will be empty....
Wow,!!!
This needs to be fixed or at least give user/buy3r à choice between longer stand-bye for quick immediate connection.and putting them back to sleep as soon as they are in the case.
Also when battery case is depleted, the buds inside stay connected...
Also annoying Soundid copy information from my clipboard
