Grell Audio,It should be a tap on the left ear to turn off/on transparent mode. If ANC was active, transparency mode turns it off. To toggle ANC, it ought to work if you hold on the left earpiece for a full second.
aptX and aptX Adaptive are currently the only Qualcomm codecs supported.
I am still trying to understand if the issue with the Play/Pause is a sensor issue that can be corrected with an app update.
Currently the Play/Pause is not consistent. I have found with testing that if I am listening for a while some music and I single tap the right side it will not execute the action ( or register the command) .However a double tap it activates the "assistant" and after that I can play and pause with no issue. If I wait again it's the same behavior.
If a future setting will be enable that allows to use double tap it would resolve this issue. Unless this is something by else.
Just in case we have 2 TWS1 units and both are having the same issue
Any help us appreciated
